Stock K Frame Weight Loss?
#1567372
01/23/14 12:13 AM
01/23/14 12:13 AM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
How many pounds can I remove from my K-Frame? It weighs 32.2 pounds at the moment.
[img] [/img]
Re: Stock K Frame Weight Loss?
[Re: clonestocker]
#1567373
01/23/14 12:48 AM
01/23/14 12:48 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
As much as you want Are you feeling lucky All kidding aside, I have seen some of them drilled full of large holes, front, back, top and bottom I had a CAP tubular K member for stock steering and torsion bars for the early,1963 to 1966 A bodys, it weighed 23 lbs, my stock one weighed 25 lbs. I'm sure the later A bodys are a little bit heavier, there bigger (I have both)
[Re: dvw]
#1567376
01/23/14 01:52 AM
01/23/14 01:52 AM
Posts: 9,848 MI, usa
dvw
MI, usa
[Re: dvw]
#1567377
01/23/14 01:53 AM
01/23/14 01:53 AM
dvw
MI, usa
[Re: dvw]
#1567378
01/23/14 01:47 PM
01/23/14 01:47 PM
Posts: 4,209 New York
polyspheric
New York
I like how you radiused the inside corners, very nice.
Boffin Emeritus
[Re: dvw]
#1567380
01/26/14 01:46 AM
01/26/14 01:46 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Is that body putty?
Be interesting if it flexes enough over time to flake and be a structural load indicator.
It looks nice.
[Re: polyspheric]
#1567381
01/26/14 08:39 PM
01/26/14 08:39 PM
dvw
MI, usa
Is that body putty?
It looks nice.
The corners were easy. I hole sawed the K before it was cut out. Yes it's bondoed. This is the second one done this way. The other one is 10 tears old, no cracks. Doug
