Valve cover studs for Indy 360-1 heads #1565399
01/19/14 02:00 PM
01/19/14 02:00 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Does anybody make them for the the thread pitch of these heads? I need them to work with fabbed aluminum valve covers too. They currently have long bolts, but I was using those in my iron heads...worried that with the aluminum I might eventually strip out the holes when bolting them back on so looking to go to studs.
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565400
01/19/14 02:07 PM
01/19/14 02:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If they are the same length as the reverse lip covers
that mount on the W2,W5,W7,W9 then you want the stud
kit P4876676 from MP
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565401
01/19/14 02:09 PM
01/19/14 02:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
there nothing special, any good hardware store with a good selection may have them. I picked up some shorter ones just the other day
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565402
01/19/14 02:19 PM
01/19/14 02:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They arent anything special... just 1/4-20 threads
in the head... most of the studs have a 1/4-28 on the
valve cover end but 1/4-20 on both ends works fine
Re: Valve cover studs for Indy 360-1 heads [Re: MR_P_BODY] #1565403
01/19/14 02:33 PM
01/19/14 02:33 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Ok I will have to measure how long I need and pick some up then...My biggest thing though, especially knowing how I am with small parts, is losing or dropping the washer and nut for each stud when removing it lol
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565404
01/19/14 02:37 PM
01/19/14 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The stud kit I showed above is real nice.. it has a
smaller extended part with a radius to help from not
dropping the nuts(nyloc nuts... no washers used)
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565405
01/19/14 02:38 PM
01/19/14 02:38 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Get some nuts, that have the incorporated washers. I used the ground strap nuts from the 80's radios. Gold irritated to boot.
Re: Valve cover studs for Indy 360-1 heads [Re: mshred] #1565406
01/19/14 03:56 PM
01/19/14 03:56 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I used studs from Canadian Tire.
Matt
Forgot
Fastenal will have what you need too.
