Re: Valve cover studs for Indy 360-1 heads
[Re: mshred]
#1565400
01/19/14 02:07 PM
01/19/14 02:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If they are the same length as the reverse lip covers that mount on the W2,W5,W7,W9 then you want the stud kit P4876676 from MP
[Re: mshred]
#1565402
01/19/14 02:19 PM
01/19/14 02:19 PM
MR_P_BODY
They arent anything special... just 1/4-20 threads in the head... most of the studs have a 1/4-28 on the valve cover end but 1/4-20 on both ends works fine
[Re: mshred]
#1565404
01/19/14 02:37 PM
01/19/14 02:37 PM
MR_P_BODY
Ok I will have to measure how long I need and pick some up then...My biggest thing though, especially knowing how I am with small parts, is losing or dropping the washer and nut for each stud when removing it lol
The stud kit I showed above is real nice.. it has a smaller extended part with a radius to help from not dropping the nuts(nyloc nuts... no washers used)
