Rubber Grommet for brake pushrod..........
#156142
11/24/08 08:15 PM
11/24/08 08:15 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Are these easy to find ? I ruined my old one,,,when i removed the pushrod from my old master cylinder. I need to put a new one on,,,,, in the past i was lucky to have one in the replacement MC....which was not the case with the MC i just got.
Re: Rubber Grommet for brake pushrod..........
[Re: JeepJimmy]
#156145
11/24/08 08:34 PM
11/24/08 08:34 PM
RapidRobert
I compared an OE one side by side to a piece of vac line & they're identical ex for the OE one has a groove cut lengthwise on the outside that does not affect fit or function. Dont remember what size of line, my parts house just snipped me off a piece.
[Re: RapidRobert]
#156146
11/24/08 08:37 PM
11/24/08 08:37 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Little cut off chunk of vacuum hose.
[Re: RapidRobert]
#156147
11/24/08 08:37 PM
11/24/08 08:37 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I used a piece of fuel line ground down to the right OD on my bench grinder.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: 69CHARGERMD]
#156148
11/24/08 08:53 PM
11/24/08 08:53 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Get the ones that Greg at MagnumHP has.They are the correct durometer material.And for the price,do as I did and get 4-5 of 'em!!
[Re: rbds65]
#156152
11/25/08 08:45 PM
11/25/08 08:45 PM
69CHARGERMD
KENTUCKY
Thanks guys,,,, i will see what i have lying around,,,,, the magnum site is down at the moment,,,but will give Greg a call............. THANKS,,,,,,,,,,,,, Doug
[Re: 69Cuda340S]
#156153
11/25/08 11:24 PM
11/25/08 11:24 PM
Posts: 182 Pennsylvania
cantspel
Pennsylvania
I've been running without on for the last 20 years and no problems. [/quote
Ever had the push rod come out of the master cylinder on a 10 sec car. If the grommet is not there, the only thing keeping the pedal from coming back and disengaging the m/c is the flimsy tab used for the brake light switch. Pretty helpless feeling going for the pedal and the rod is against the firewall. Destroyed a $20K car over that rubber grommet. you need it. I also make a positive stop for my brake pedals now. Not too hard to get your foot accidentally behind the brake pedal when going to tag the brakes@ 135 so as not to hog the finish line.
