Rubber Grommet for brake pushrod.......... #156142
11/24/08 08:15 PM
11/24/08 08:15 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Are these easy to find ?
I ruined my old one,,,when i removed the pushrod from my old master cylinder.
I need to put a new one on,,,,,
in the past i was lucky to have one in the replacement MC....which was not the case with the MC i just got.
Re: Rubber Grommet for brake pushrod.......... [Re: 69CHARGERMD] #156143
11/24/08 08:19 PM
11/24/08 08:19 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I've been running without on for the last 20 years and no problems.
Re: Rubber Grommet for brake pushrod.......... [Re: 69CHARGERMD] #156144
11/24/08 08:24 PM
11/24/08 08:24 PM
eastern long island,NY
JeepJimmy Offline
JeepJimmy  Offline
you need it! www.magnumhp.com
70 duster 360magnum, 1975 jeep j-10.
Re: Rubber Grommet for brake pushrod.......... [Re: JeepJimmy] #156145
11/24/08 08:34 PM
11/24/08 08:34 PM
I compared an OE one side by side to a piece of vac line & they're identical ex for the OE one has a groove cut lengthwise on the outside that does not affect fit or function. Dont remember what size of line, my parts house just snipped me off a piece.
Re: Rubber Grommet for brake pushrod.......... [Re: RapidRobert] #156146
11/24/08 08:37 PM
11/24/08 08:37 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Little cut off chunk of vacuum hose.
Re: Rubber Grommet for brake pushrod.......... [Re: RapidRobert] #156147
11/24/08 08:37 PM
11/24/08 08:37 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I used a piece of fuel line ground down to the right OD on my bench grinder.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Rubber Grommet for brake pushrod.......... [Re: 69CHARGERMD] #156148
11/24/08 08:53 PM
11/24/08 08:53 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Get the ones that Greg at MagnumHP has.They are the correct durometer material.And for the price,do as I did and get 4-5 of 'em!!
Nautilus Racing-
Re: Rubber Grommet for brake pushrod.......... [Re: 69CHARGERMD] #156149
11/24/08 09:52 PM
11/24/08 09:52 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I used a rubber vacuum cap.
Re: Rubber Grommet for brake pushrod.......... [Re: Chris2581] #156150
11/24/08 09:59 PM
11/24/08 09:59 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I got a dozen of them from him also a couple years ago. They DO NOT come with rebuilt masters!
JB Rhinehart, Realist
A-Body's RULE!
Re: Rubber Grommet for brake pushrod.......... [Re: 69CHARGERMD] #156151
11/25/08 01:59 PM
11/25/08 01:59 PM
KY
rbds65 Offline
rbds65  Offline
KY
Doug, I also used a short piece of vacuum hose. RBD
Re: Rubber Grommet for brake pushrod.......... [Re: rbds65] #156152
11/25/08 08:45 PM
11/25/08 08:45 PM
KENTUCKY
KENTUCKY
Thanks guys,,,,
i will see what i have lying around,,,,,
the magnum site is down at the moment,,,but will give Greg a call.............
THANKS,,,,,,,,,,,,,
Doug
Re: Rubber Grommet for brake pushrod.......... [Re: 69Cuda340S] #156153
11/25/08 11:24 PM
11/25/08 11:24 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
I've been running without on for the last 20 years and no problems. [/quote
Ever had the push rod come out of the master cylinder on a 10 sec car. If the grommet is not there, the only thing keeping the pedal from coming back and disengaging the m/c is the flimsy tab used for the brake light switch. Pretty helpless feeling going for the pedal and the rod is against the firewall. Destroyed a $20K car over that rubber grommet. you need it. I also make a positive stop for my brake pedals now. Not too hard to get your foot accidentally behind the brake pedal when going to tag the brakes@ 135 so as not to hog the finish line.
