Re: BB Comp Steel roller rockers
[Re: Cab_Burge]
#1561131
01/09/14 03:53 PM
01/09/14 03:53 PM
Posts: 4,799 ILL
MLR426
ILL
Will the comp steel roller rockers fit under stock big block valve covers. Do they have enough clearance ??
MLR426
Probally not, I would check them first before doing anything else I would expect the adjusters to hit the stock baffles I have bent, dented or cut holes in the stock baffles to make the stock covers work when the customers wanted the stock look
Yes and thats what I'm up against, I will have to bend etc for fit. didn't someone have a 1/4 spacer made ??
MLR426
[Re: MLR426]
#1561133
01/09/14 09:54 PM
01/09/14 09:54 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
MLR426
Mine fit without clearance issues. The rocker is actually pretty compact and the adjuster does not stick up real high.
[Re: mrrandyj]
#1561135
01/10/14 02:21 PM
01/10/14 02:21 PM
dartman366
Mt. Vernon, Ohio
I bought a set of spacers from topside340 here on the board, these are for a Small block, he may have them for a BB, just PM him.
