BB Comp Steel roller rockers #1561129
01/09/14 12:45 PM
01/09/14 12:45 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Will the comp steel roller rockers fit under stock big block valve covers. Do they have enough clearance ??
MLR426
Re: BB Comp Steel roller rockers [Re: MLR426] #1561130
01/09/14 03:31 PM
01/09/14 03:31 PM
MLR426
Probally not, I would check them first before doing anything else I would expect the adjusters to hit the stock baffles I have bent, dented or cut holes in the stock baffles to make the stock covers work when the customers wanted the stock look
Re: BB Comp Steel roller rockers [Re: Cab_Burge] #1561131
01/09/14 03:53 PM
01/09/14 03:53 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
MLR426
Yes and thats what I'm up against, I will have to bend etc for fit. didn't someone have a 1/4 spacer made ??
MLR426
Re: BB Comp Steel roller rockers [Re: MLR426] #1561132
01/09/14 04:07 PM
01/09/14 04:07 PM
You could stack multiple cork/rubber valve cover gaskets together to raise the covers I've done that on the Hemiroid motors
Re: BB Comp Steel roller rockers [Re: MLR426] #1561133
01/09/14 09:54 PM
01/09/14 09:54 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
MLR426
Mine fit without clearance issues. The rocker is actually pretty compact and the adjuster does not stick up real high.
Re: BB Comp Steel roller rockers [Re: MLR426] #1561134
01/10/14 12:56 PM
01/10/14 12:56 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Mine fit fine with the stock valve covers and baffles.
Re: BB Comp Steel roller rockers [Re: mrrandyj] #1561135
01/10/14 02:21 PM
01/10/14 02:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I bought a set of spacers from topside340 here on the board, these are for a Small block, he may have them for a BB, just PM him.
