sub frame connertors #1560430
01/07/14 04:08 PM
01/07/14 04:08 PM
Canada
Dons Dart Offline OP
Canada
Hi just bought some mopar sub frame connectors for my 69 DART,looking for tips and advice on how to install them.some say put the car on jack stands, level and thats it others say its better with the suspension loaded.
Re: sub frame connertors [Re: Dons Dart] #1560431
01/07/14 04:10 PM
01/07/14 04:10 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Which type of connectors ? ...TO the floor or THROUGH THE floor ?
Re: sub frame connertors [Re: dOrk !] #1560432
01/07/14 04:15 PM
01/07/14 04:15 PM
Canada
Canada
They don't go through the floor p# 4876658.
Re: sub frame connertors [Re: Dons Dart] #1560433
01/07/14 04:19 PM
01/07/14 04:19 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
IMO .... to the floor are not nearly as effective as the THROUGH THE FLOOR type are ...
Re: sub frame connertors [Re: dOrk !] #1560434
01/07/14 07:35 PM
01/07/14 07:35 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
PM Not needed.
those are BOLT in connectors.
ricky
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: sub frame connertors [Re: Copper Dart] #1560435
01/07/14 07:40 PM
01/07/14 07:40 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
...the bolt-on connectors are even WORSEless ...IMO... vs the others.
Re: sub frame connertors [Re: dOrk !] #1560436
01/07/14 09:01 PM
01/07/14 09:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure i would say "worthless", but I would say they (typical bolt in style) are not worth the effort/time/cost.
Re: sub frame connertors [Re: Dons Dart] #1560437
01/07/14 10:00 PM
01/07/14 10:00 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
I built my own out of 2 X 4 tubing and welded them directly to the front and rear sub frames, they don't touch the floor anywhere in the middle but I can jack up the car at the front or back weld spot and lift the whole side of the car. The car handles corners much better now rides real nice.
So if you can weld them in place with the car setting on the suspension and weight on the drivers seat.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: sub frame connertors [Re: dOrk !] #1560438
01/07/14 10:04 PM
01/07/14 10:04 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Whatever....this topic comes up on every board. Here's what I think..take it or leave it.
Unless you're racing the car(drag or road coarse)ANY frame connector is a HUGE improvement! I built mine(no they don't go through the floor) and welded them. They made a huge improvement in ride and handling quality. Eliminated many squeaks and rattles too! Mine is just a street car but it feels a lot tighter,more responsive.
If you have these connectors and it's a street toy....get it on a drive on style hoist with the weight on the wheels, bolt them on..then weld them up! You will be happy with the results!
If this is a race car...think about something that connects/goes through the floor for maximum effectiveness
Re: sub frame connertors [Re: OldMoparMan] #1560439
01/07/14 10:06 PM
01/07/14 10:06 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
I agree. I bought the MP bolt in connectors but welded them in instead. I can lift the whole side by lifting the front or back sub frame. The car handles 100 percent better. No more twisting and turning on curvy roads. One of the best investments I've made on my Dart.
1970 Duster 340 clone
Re: sub frame connertors [Re: OldMoparMan] #1560440
01/07/14 10:09 PM
01/07/14 10:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Been doing them that way for years!
Mopar Ford & GM I sit the car on pieces of railroad cross tie & stack concrete blocks the simulate driver weight in the seat
Re: sub frame connertors [Re: BulletBob] #1560441
01/07/14 10:11 PM
01/07/14 10:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The only real subframe connectors bolt in with .035 wire & go through the floor
Re: sub frame connertors [Re: Dons Dart] #1560442
01/08/14 12:59 AM
01/08/14 12:59 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I made mine (67 Dart) with I believe 1.5x3" thick wall rectangular tubing, notched for the back of course. It fit the frame rail perfectly, and butts up against the front frame. The parking brake cable required some filing of the connector, but no big deal. And yes I can lift the car with it etc.
Re: sub frame connertors [Re: Exit1965] #1560443
01/08/14 02:01 AM
01/08/14 02:01 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: sub frame connertors [Re: Dcuda69] #1560444
01/08/14 04:41 AM
01/08/14 04:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this. Mine dont go thru the floor so I bolted them in place and then welded them. And I have a 6 point rollbar welded in overtop the unibody frame. But I do race once or twice a year. Ron
Re: sub frame connertors [Re: 383man] #1560445
01/08/14 12:03 PM
01/08/14 12:03 PM
Canada
Canada
Ok good thoughts I do plan on having them welded in the summer,plan to do the bolt on now,i i know some of you don't like the mp bolt on but i am old school look.so what is the diff doing it on jack stands vs with the suspension loaded i realty want to do this at home over the winter.
Re: sub frame connertors [Re: Dons Dart] #1560446
01/08/14 12:05 PM
01/08/14 12:05 PM
Canada
Canada
ya its just a street toy
Re: sub frame connertors [Re: Dons Dart] #1560447
01/08/14 12:42 PM
01/08/14 12:42 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
As long as the panels line up and doors open smoothly, bolt em up and call it good. It'll be worlds better than stock. Then when you have time, burn em in. Don't let people scare you. You've already got them. Use them!!
Re: sub frame connertors [Re: mopowers] #1560448
01/08/14 12:48 PM
01/08/14 12:48 PM
Canada
Canada
thanks.
Re: sub frame connertors [Re: BrianT] #1560449
01/08/14 01:05 PM
01/08/14 01:05 PM
Canada
Canada
Brian how did you do your install on a drive on lift or on jack stands?
