Re: sub frame connertors
[Re: dOc !]
#1560434
01/07/14 07:35 PM
01/07/14 07:35 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
PM Not needed. those are BOLT in connectors. ricky
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: dOc !]
#1560436
01/07/14 09:01 PM
01/07/14 09:01 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Not sure i would say "worthless", but I would say they (typical bolt in style) are not worth the effort/time/cost.
[Re: dOc !]
#1560438
01/07/14 10:04 PM
01/07/14 10:04 PM
Posts: 4,941 WI
Dcuda69
WI
Whatever....this topic comes up on every board. Here's what I think..take it or leave it. Unless you're racing the car(drag or road coarse)ANY frame connector is a HUGE improvement! I built mine(no they don't go through the floor) and welded them. They made a huge improvement in ride and handling quality. Eliminated many squeaks and rattles too! Mine is just a street car but it feels a lot tighter,more responsive. If you have these connectors and it's a street toy....get it on a drive on style hoist with the weight on the wheels, bolt them on..then weld them up! You will be happy with the results! If this is a race car...think about something that connects/goes through the floor for maximum effectiveness
[Re: OldMoparMan]
#1560439
01/07/14 10:06 PM
01/07/14 10:06 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I agree. I bought the MP bolt in connectors but welded them in instead. I can lift the whole side by lifting the front or back sub frame. The car handles 100 percent better. No more twisting and turning on curvy roads. One of the best investments I've made on my Dart.
1970 Duster 340 clone
[Re: OldMoparMan]
#1560440
01/07/14 10:09 PM
01/07/14 10:09 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I built my own out of 2 X 4 tubing and welded them directly to the front and rear sub frames, they don't touch the floor anywhere in the middle but I can jack up the car at the front or back weld spot and lift the whole side of the car. The car handles corners much better now rides real nice.
So if you can weld them in place with the car setting on the suspension and weight on the drivers seat.
Been doing them that way for years! Mopar Ford & GM I sit the car on pieces of railroad cross tie & stack concrete blocks the simulate driver weight in the seat
[Re: Dons Dart]
#1560446
01/08/14 12:05 PM
01/08/14 12:05 PM
Posts: 440 Canada
Dons Dart
Canada
Ok good thoughts I do plan on having them welded in the summer,plan to do the bolt on now,i i know some of you don't like the mp bolt on but i am old school look.so what is the diff doing it on jack stands vs with the suspension loaded i realty want to do this at home over the winter.
ya its just a street toy
[Re: mopowers]
#1560448
01/08/14 12:48 PM
01/08/14 12:48 PM
Posts: 440 Canada
Dons Dart
Canada
As long as the panels line up and doors open smoothly, bolt em up and call it good. It'll be worlds better than stock. Then when you have time, burn em in. Don't let people scare you. You've already got them. Use them!!
thanks.
[Re: BrianT]
#1560449
01/08/14 01:05 PM
01/08/14 01:05 PM
Posts: 440 Canada
Dons Dart
Canada
Brian how did you do your install on a drive on lift or on jack stands?
