Milodon 31151 - Milodon Drag Racing Oil Pans
#1559241
01/05/14 11:49 AM
01/05/14 11:49 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Anyone running this oil pan? Milodon 31151 I picked up a used one but I'm wondering if I should use the 9qt version rather than this 7qt version? I called Milodon and asked them and they thought it would be fine because of how the oil was controlled with this pan compared with the center sump pans. They also told me that I could cap off one of the swinging pick ups and just run a singe line oil pick up with a Melling HV oil pump as long as I kept the RPMs 7,300 or less. So that is my current plan but wanted to ask others about their experiences.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Milodon 31151 - Milodon Drag Racing Oil Pans
[Re: Stanton]
#1559245
01/06/14 01:25 PM
01/06/14 01:25 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Been using the 7qt pan for a long time and it works great and gives a ton of ground clearance. You will need to run the full 7qrts though, mine would lose oil pressure on the brakes with less than 7.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
