Milodon 31151 - Milodon Drag Racing Oil Pans #1559241
01/05/14 11:49 AM
01/05/14 11:49 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Anyone running this oil pan?
Milodon 31151
I picked up a used one but I'm wondering if I should use the 9qt version rather than this 7qt version?
I called Milodon and asked them and they thought it would be fine because of how the oil was controlled with this pan compared with the center sump pans. They also told me that I could cap off one of the swinging pick ups and just run a singe line oil pick up with a Melling HV oil pump as long as I kept the RPMs 7,300 or less.
So that is my current plan but wanted to ask others about their experiences.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Milodon 31151 - Milodon Drag Racing Oil Pans [Re: WadeMetzinger] #1559242
01/05/14 12:40 PM
01/05/14 12:40 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I just had one built exactly the same way except with the center link hole.
I would run dual lines though. 1 -12AN line would not be enough IMHO.
A single -20 AN line would be suffice.
Re: Milodon 31151 - Milodon Drag Racing Oil Pans [Re: Sammy] #1559243
01/05/14 05:09 PM
01/05/14 05:09 PM
Tulsa, Ok
Tulsa, Ok
Will the pumps covers support a -20 line? (So just swap out the fitting on the pump? I could use a Y fitting from the pan to combine the two -12 lines into a -20 line)
Re: Milodon 31151 - Milodon Drag Racing Oil Pans [Re: WadeMetzinger] #1559244
01/05/14 09:57 PM
01/05/14 09:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The cover won't take a -20. What is that ... like a rad hose ?!?!?
How do you put a link hole in a low profile pan like that ?!?!?
I think Milodon probably have a pretty good idea of what they're talking about !
Re: Milodon 31151 - Milodon Drag Racing Oil Pans [Re: Stanton] #1559245
01/06/14 01:25 PM
01/06/14 01:25 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Been using the 7qt pan for a long time and it works great and gives a ton of ground clearance. You will need to run the full 7qrts though, mine would lose oil pressure on the brakes with less than 7.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Milodon 31151 - Milodon Drag Racing Oil Pans [Re: Jacob Pitt] #1559246
01/06/14 04:47 PM
01/06/14 04:47 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I don't run that short of a pan, but I do run a dual line swinging pick up with one port hole blocked at the pick up. A single -12 line to a Melling HV oil pump with a Milodon pump cover going to a remote oil filter base. Routinely see 7000 rpm's with no oiling problems at all. The pan is a Milodon SS pan. Couple that with a Wix filter and all the lines, its a 10 qt system. I also added a Peterson scavenge filter at the oil pan. The only draw back to this system is ground clearance (or rather the lack of).
Brian
