Anyone using MRL big block solid roller lifters? #1558328
01/03/14 06:22 PM
01/03/14 06:22 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I came across some posts on other Mopar boards about solid roller lifter that MRL Performance came out with maybe a year ago. Anyone here use them in big blocks, in particular blocks with unbushed lifter bores?
MRL also offers two different types, one with a standard .750 wheel and an upgrade that has a .815". Is there really a performance benefit to a larger wheel or is it just better durability by spreading the load out a little more?
Re: Anyone using MRL big block solid roller lifters? [Re: PorkyPig] #1558329
01/03/14 09:06 PM
01/03/14 09:06 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I just ordered the small block version.
It was explained to me the bigger roller will distribute the weight better but the smaller roller will work if the valve train is set up properly...I went for the smaller roller.
I'm cheap.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Anyone using MRL big block solid roller lifters? [Re: PorkyPig] #1558330
01/03/14 11:06 PM
01/03/14 11:06 PM
gregsdart Offline
gregsdart  Offline
Check and see if the roller wheel you want will work with your cam. Different diameters change the rate of lift and may be too fast or too slow for best performance.
Re: Anyone using MRL big block solid roller lifters? [Re: gregsdart] #1558331
01/04/14 02:53 AM
01/04/14 02:53 AM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
Yes, I saw these as well. I will be in the market later this year for a set of rollers, and the advertising sure seems good on these. Does anyone know who manufactures these lifters?
Re: Anyone using MRL big block solid roller lifters? [Re: PorkyPig] #1558332
01/05/14 02:31 PM
01/05/14 02:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd like to see a pic comparing the two versions of big-block lifters. I Googled around some after seeing this topic and found one for the small-block lifters, but the big-block lifter pics look a bit different than the small-block stuff (not just the link bars).
Re: Anyone using MRL big block solid roller lifters? [Re: Kelob_pie] #1558333
01/05/14 06:08 PM
01/05/14 06:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mike told me they're made here by a couple of ex-crane engineers. IIRC they retired down in Florida and got bored lol.
Mopar to the bone!!!
Re: Anyone using MRL big block solid roller lifters? [Re: gregsdart] #1558334
01/05/14 06:15 PM
01/05/14 06:15 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Explain please. Makes sense???
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Anyone using MRL big block solid roller lifters? [Re: slippery440] #1558335
01/05/14 07:00 PM
01/05/14 07:00 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I have spoken with Mike about the small block ones...he explained to me the cheaper ones (pro sports) have a narrower roller and were only good for up to 650lbs open spring pressure...the more expensive ones (pro plus) use a wider wheel and can take more spring pressure, and also have a lightened body...Price difference is $480 compared to $620 I think it was?
I am going to order a set, just have to find the time to get the old valvesprings off of my heads, decide what springs I am going to use and see the pressures before I choose which ones I will go with.
Re: Anyone using MRL big block solid roller lifters? [Re: slippery440] #1558336
01/06/14 04:26 AM
01/06/14 04:26 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Think of it just like rollout on a tire. Now approach a bump in the road with a really tall tire or a really short tire. Does that change the way the car "feels" across the bump........yes sir, big time.
Monte
Re: Anyone using MRL big block solid roller lifters? [Re: Monte_Smith] #1558337
01/06/14 01:39 PM
01/06/14 01:39 PM
BradH Offline
BradH  Offline
Monte
I'll throw this in,too: http://www.cranecams.com/bulletins_listview.php?s_id=9
Re: Anyone using MRL big block solid roller lifters? [Re: BradH] #1558338
01/06/14 02:40 PM
01/06/14 02:40 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Thank -You Monte and Brad. I learned something today. Never ever thought about roller size and the efects it causes to the cam.
Re: Anyone using MRL big block solid roller lifters? [Re: gregsdart] #1558339
01/06/14 03:09 PM
01/06/14 03:09 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I just recieved a set of his Pro Sport lifter. They look pretty good the machining is great. I decided agaist the pros because my piston to valve clearance is on the tight side now(int-.060/ex-.090)and I didn't want to loose any. I don't think the roller on the Pros are wider, just a larger diameter with larger diameter roller bearings. The box said BAM Products. The engineers name is Brad Miller. Hopefully they hold up well. I usually don't like to be a guinea pig, but the price is great and they have the good features.
Re: Anyone using MRL big block solid roller lifters? [Re: gregsdart] #1558340
01/09/14 07:44 PM
01/09/14 07:44 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Cam company says my lobes will work with .750 to .825 roller wheels.
Re: Anyone using MRL big block solid roller lifters? [Re: PorkyPig] #1558341
01/12/14 06:57 PM
01/12/14 06:57 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Can the MRL's be used in a small block without the bores being bushed or the lifter galley oil passage being blocked off?
Re: Anyone using MRL big block solid roller lifters? [Re: bill_greenwood] #1558342
01/14/14 01:07 PM
01/14/14 01:07 PM
BradH Offline
BradH  Offline
If you're still looking for the answer, you're better off contacting MRL directly.
Re: Anyone using MRL big block solid roller lifters? [Re: BradH] #1558343
01/14/14 01:32 PM
01/14/14 01:32 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
x2
