Re: Anyone using MRL big block solid roller lifters?
[Re: PorkyPig]
#1558329
01/03/14 09:06 PM
01/03/14 09:06 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I just ordered the small block version.
It was explained to me the bigger roller will distribute the weight better but the smaller roller will work if the valve train is set up properly...I went for the smaller roller.
I'm cheap.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: PorkyPig]
#1558330
01/03/14 11:06 PM
01/03/14 11:06 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Check and see if the roller wheel you want will work with your cam. Different diameters change the rate of lift and may be too fast or too slow for best performance.
[Re: slippery440]
#1558336
01/06/14 04:26 AM
01/06/14 04:26 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Explain please. Makes sense???
Think of it just like rollout on a tire. Now approach a bump in the road with a really tall tire or a really short tire. Does that change the way the car "feels" across the bump........yes sir, big time.
Monte
[Re: Monte_Smith]
#1558337
01/06/14 01:39 PM
01/06/14 01:39 PM
BradH
Monte
I'll throw this in,too: http://www.cranecams.com/bulletins_listview.php?s_id=9
[Re: gregsdart]
#1558339
01/06/14 03:09 PM
01/06/14 03:09 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
I just recieved a set of his Pro Sport lifter. They look pretty good the machining is great. I decided agaist the pros because my piston to valve clearance is on the tight side now(int-.060/ex-.090)and I didn't want to loose any. I don't think the roller on the Pros are wider, just a larger diameter with larger diameter roller bearings. The box said BAM Products. The engineers name is Brad Miller. Hopefully they hold up well. I usually don't like to be a guinea pig, but the price is great and they have the good features.
[Re: gregsdart]
#1558340
01/09/14 07:44 PM
01/09/14 07:44 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Cam company says my lobes will work with .750 to .825 roller wheels.
[Re: bill_greenwood]
#1558342
01/14/14 01:07 PM
01/14/14 01:07 PM
BradH
Can the MRL's be used in a small block without the bores being bushed or the lifter galley oil passage being blocked off?
If you're still looking for the answer, you're better off contacting MRL directly.
[Re: BradH]
#1558343
01/14/14 01:32 PM
01/14/14 01:32 PM
PorkyPig
x2
