Rons Fuel Injection... #155621
11/23/08 11:29 PM
11/23/08 11:29 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Who has it and would you run it on the street...
Re: Rons Fuel Injection... [Re: joshking440] #155622
11/23/08 11:33 PM
11/23/08 11:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I do...
No....
If you try, better have a 55 gallon fuel cell
Re: Rons Fuel Injection... [Re: Bob_Coomer] #155623
11/23/08 11:39 PM
11/23/08 11:39 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
can u run E85 through it? and when I say street car i mean drag car that you cruise once in a while
Re: Rons Fuel Injection... [Re: joshking440] #155624
11/23/08 11:45 PM
11/23/08 11:45 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
The mechanical fuel injection system does not have the ability to instantly add fuel like a carb (no accelerator pump). So it would be difficult to drive on the street - bog at even the slightest the touch of the throttle from idle, followed by a sudden surge of power.
Scott
Re: Rons Fuel Injection... [Re: joshking440] #155625
11/24/08 01:05 AM
11/24/08 01:05 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Yes they have one that is for E85. I seriously doubt that you could run it on a street car. Give James Monroe a call there in Indy. 812-327-1190. Tell him that Eric Paul sent you.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Rons Fuel Injection... [Re: Irun5snd8th] #155626
11/24/08 02:40 AM
11/24/08 02:40 AM
ProStDodge Offline
ProStDodge  Offline
Never tried it with gas or on the street, but I have run the Ron's systems before and loved it for racing.
Scott
Re: Rons Fuel Injection... [Re: joshking440] #155627
11/24/08 03:11 AM
11/24/08 03:11 AM
New Mexico
Scott440 Offline
Scott440  Offline
New Mexico
if it's low cost you seek, i would recommend looking at howell efi or holley.
i think howells mpfi can barely handle a 500" motor. the tbi is 1/2 capable, but call them and check.
you could get howell's tbi system for about 1100 and add a second fuel pump + throttle body perhaps from eBay. it's cheaper and safer than megasquirt ... i think mopars have to use universal, but amc V8s have specific kits at howells. go figure.
dont assume more expensive kits run good "out of the box" -- none do.
in theory, even a tbi would probably be better for a blown car than a specially prepped carb.
Re: Rons Fuel Injection... [Re: Scott440] #155628
11/24/08 09:12 AM
11/24/08 09:12 AM
Indy
Lunch is on me!
Lunch is on me!
Indy
Well to add to the discussion, I am going to be blowing thru with an F2 procharger...
Re: Rons Fuel Injection... [Re: joshking440] #155629
11/24/08 09:51 AM
11/24/08 09:51 AM
NC
440Jim Offline
440Jim  Offline
NC
The real answer is to discuss it with James Monroe at KillerRon's
http://www.killerrons.com/
Also read his and the Ronsfuel web site information.
http://www.ronsfuel.com/
I don't know the streetability of it, but I would think the instant supply of fuel of an injection system would be better than a carb's accelerator pumps. And the "Terminator" throttle bodies should be even better than the "Flying Toilet" for part throttle use.
Re: Rons Fuel Injection... [Re: 440Jim] #155630
11/24/08 11:07 AM
11/24/08 11:07 AM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
Read the post I have on my uncles car and e85 we've only run it one week end but I can tell you throttle response is instant from 500 rpms and this is with a big chevy with square port heads and .700 lift roller.I dont see why you couldnt run it on the street I do not think fuel milage would be great because it has to be rich at idle and part throttle to over come the lack of any king of enrichment.
Re: Rons Fuel Injection... [Re: 440Jim] #155631
11/24/08 02:11 PM
11/24/08 02:11 PM
ProStDodge Offline
ProStDodge  Offline
I tried using the toilet system with a blow-thru setup. I was using alcohol not gas or E-85, and it was a race car not a street car. The blow-thru toilet worked, but a BOV is NEEDED. The throttle blade is large enough that when the throttle was snapped shut at the big end, there was enough pressure on the blade to bind the throttle shaft, sticking the car at about 3/4 throttle. This problem did not appear until most of the way through the season. So apparently the pressure was wearing the throttle blade pivots, or had bent the throttle shaft.
A BOV would have bled off the extra pressure and should have prevented this problem. A the time I purchased a Terminator throttle body, figuring the smaller blades and better shaft support should cure the isse, but never got around to installed it (still on the shelf).
Scotty
Re: Rons Fuel Injection... [Re: ProStDodge] #155632
11/25/08 10:24 PM
11/25/08 10:24 PM
New Mexico
Scott440 Offline
Scott440  Offline
New Mexico
a bov that blows straight out the atmosphere -- ok. but high psi and NO bov -- never heard of it.
Post deleted by Defbob [Re: joshking440] #155633
01/04/10 10:13 PM
01/04/10 10:13 PM
Re: Rons Fuel Injection... #155634
01/04/10 10:31 PM
01/04/10 10:31 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I had the T2 methanol system and loved it ,but it was race only .
It never bogged ever, anytime.
In Boosted applications I think you would be crazy not to go with EFI.
There are lots of other guys to compare notes with, and its self calibrating.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Rons Fuel Injection... [Re: joshking440] #155635
01/05/10 11:10 PM
01/05/10 11:10 PM
NC
440Jim Offline
440Jim  Offline
NC
I recalibrated my Ron's Flying Toilet injection from methanol to E85. It works great. I ran most of the 2009 season on E85 (started the season on methanol). With the wide band oxygen sensor to help tune it, it was pretty easy.
