Starting a dormant engine #1555920
12/30/13 04:36 PM
12/30/13 04:36 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
I need to fire up the 440 for the first time in three years soon, and was wondering what I should do to it before starting? I am going to change the oil/filter and pre lube it. Anything else? It does have a solid cam, do I need to check the valve lash? Obviously, I will be putting in fresh fuel also.
Dennis
Re: Starting a dormant engine [Re: cudaboy] #1555921
12/30/13 05:06 PM
12/30/13 05:06 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
It wouldn't hurt to check, but it will be the same as it was when parked.
Pre lube it, and I'd throw fresh plugs in. Maybe check the carb out (although I usually don't bother until after I have it running). If it has points I usually change them out.
Re: Starting a dormant engine [Re: cudaboy] #1555922
12/30/13 06:05 PM
12/30/13 06:05 PM
I would do as you are and add(squirt) some ATF, not a bunch , into each cylinder and leave all the spark plugs out and then prime it, once you have oil pressure spin the motor over on the starter for four or five burst of ten to twenty seconds each to lube the rockers and everything else
Re: Starting a dormant engine [Re: cudaboy] #1555923
12/30/13 06:53 PM
12/30/13 06:53 PM
when your (drill) priming it turn it so the rotor is at #6 for a minute then turn it to #8 for a minute so the pass & dr heads can oil. What Cab said I'd pull the plugs & oil the cyls/rings. I would open the carb & see what it looks like in there & then when back together fill the bowls by hand & new plugs as needed.
Re: Starting a dormant engine [Re: RapidRobert] #1555924
12/30/13 07:07 PM
12/30/13 07:07 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Put in some zinc additive too. Comp Cams break in oil or similar.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Starting a dormant engine [Re: gregsrt] #1555925
12/30/13 08:26 PM
12/30/13 08:26 PM
NJ
JH23 Offline
JH23  Offline
NJ
Pour a quart of ATF down the intake and let it sit for a week. Remove the plugs. Squirt some ATF in the cylinders the ATF didnt get into. Then slowly turn the crank back and forth until you are satisfied the engine turns freely. Then crank it to blow out the ATF.
