It wouldn't hurt to check, but it will be the same as it was when parked.
Pre lube it, and I'd throw fresh plugs in. Maybe check the carb out (although I usually don't bother until after I have it running). If it has points I usually change them out.
Now I need to pin those needles, got to feel that heat
Hear my motor screamin while I'm tearin up the street
