Stroker Hemi combos, ET/power #s #1554948
12/29/13 03:49 AM
12/29/13 03:49 AM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
Cabin fever is here. Boxes of parts complied for my Hemi but no time for my own stuff and much more parts/$ needed anyhow. Was thinking you guys and gals could share some of your badass Hemi builds to hold me over? Size, basic combo, et/power #s etc. Street or strip, all good to me!
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554949
12/29/13 11:26 AM
12/29/13 11:26 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
New Build 1
Ain't nuthin like a HEMI !
Re: Stroker Hemi combos, ET/power #s [Re: Mulehead] #1554950
12/29/13 11:26 AM
12/29/13 11:26 AM
Mulehead Offline
Mulehead  Offline
New Build 2
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554951
12/29/13 01:48 PM
12/29/13 01:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
505" al KB, 10.71 BDS, 246*/256* roller.
640+ RWHP on pump gas. 68 Dart street/strip car.
Master, again and still
Re: Stroker Hemi combos, ET/power #s [Re: DaveRS23] #1554952
12/29/13 02:12 PM
12/29/13 02:12 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Well...I detuned my Hemi for reliability and to be legal Nostalgia Mod Gas....Still 11.6:1 compression, still pump gas friendly, 484 cubes, good flowing heads but more room in them yet maybe 20cfm, good size valves, ported intake...It definitly liked the TR better, but I have an SV1 on the way that should wake it up...
Made +750hp Injected with a real cam....
Under carburated and with a very mild cam, and less valve spring pressure, its made 665hp so far with an ignition miss, and a crack in the intake...Had the intake welded up and I think I found the ignition miss...Still tuning it though.
Re: Stroker Hemi combos, ET/power #s [Re: Dragula] #1554953
12/29/13 03:45 PM
12/29/13 03:45 PM
California
mickm Offline
mickm  Offline
California
not the best picture...
540 c.i. 10.3:1, 248/255 - .605/.588 cam, stage V heads and intake, 2 edelbrock 650's. did 712 at 6k, now using that to tear up the rear tires!
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554954
12/29/13 07:32 PM
12/29/13 07:32 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I haven't had this one on the dyno, and only a few times down the track. The entire car is a new build and not dialed in.
My Hemi is 572" alum. World block, CP 10.5 pistons, Stage V replacement heads CNC @ MCH. Comp solid roller from Dwayne Porter. The carb is a 4150 race Demon RS for now, and that is where I am looking to make changes. I have a 426- 3 and a Rat Roaster X ram to play with in the future.
Not pushing the car hard at all, short shifting about 6,000. Have three passes with best of 6.13 @ 113.3 mph.
Running pump gas.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Stroker Hemi combos, ET/power #s [Re: Hemi Allstate] #1554955
12/29/13 09:20 PM
12/29/13 09:20 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow 415@800 lift. 760,740 284@.50 roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run.
Re: Stroker Hemi combos, ET/power #s [Re: grncpe] #1554956
12/30/13 04:12 AM
12/30/13 04:12 AM
White Creek, NY
408cuda Offline OP
408cuda  Offline OP
White Creek, NY
Awesome iron. Some quality hot rods for sure.
My build is much like Mickm, 520-540ish Stage V street/strip 4 speed.
Have you had yours to the strip at all Mick?
Thanks guys, keep em coming. Winter here is looong!
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554957
12/30/13 08:48 AM
12/30/13 08:48 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. 853hp@5800, 818ftlbs@4800. Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at 10.74@108. Dave
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554958
12/30/13 08:50 AM
12/30/13 08:50 AM
pa
572charger Offline
572charger  Offline
pa
606 cuin stage V big valve heads flow 450 at 28" 700 lift 720 lift roller 282 dur no2 cam 11.9 to 1 comp callies oliver diamond milodon gear drive ray barton oil pump charlies pan best run with single 1250 cfm dom and ray barton intake 9.60 at 141.79 on 93 octane pumpgas and 8.93 at 156 mph on a 200 hp tune , driven to the track and driven home 48 mile round trip , i weighs 3910 with me so u can do the HP math
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Stroker Hemi combos, ET/power #s [Re: grncpe] #1554959
12/30/13 09:59 AM
12/30/13 09:59 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow [Email]415@800[/Email] lift. 760,740 [Email]284@.50[/Email] roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run.
[url=http://s823.photobucket.com/user/FabBakers/media/DSC01727_zps487fa57b.jpg.html]
Now thats tuff !
Here's mine - will be in at around 3500lbs. Made 845HP/770TQ, I hope I can go as fast as you have
Hemi mega block 4.5" bore - o-ringed
4.5" Bryant crank
Saenz 7.1" rods
11:1 Diamond pistons - coated tops/skirts
Sealed Power rings
ARP rod, crank, head studs, oil pan studs, flywheel bolts
Bullet roller 752/684" lift 270/280 @ .050" 112 & Isky Red Zone Xtreme EZ roller lifters
Indy Legend heads ported 420 cfm
Stage V rollers
MSD dist/box/crank trigger
Indy 426-4 4500 intake/have a 4500 Barton intake as well
Pro systems 1150
Electric water pump
Milodon ext dual line swinging pickup and pump
727 with all the good gear
Ultimate Convertor
9" 4.11s
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554960
12/30/13 05:27 PM
12/30/13 05:27 PM
California
mickm Offline
mickm  Offline
California
no, haven't made it yet. dealing with a bunch of issues, most notably an ignition system that either misses badly near the rev limit, or has no rev limit.
hopefully this spring/summer.
Re: Stroker Hemi combos, ET/power #s [Re: quickd100] #1554961
12/30/13 05:35 PM
12/30/13 05:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. [Email]853hp@5800[/Email], [Email]818ftlbs@4800.[/Email] Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at [Email]10.74@108.[/Email] Dave
This is too cool right there..............hopefully you can get the damage fixed and get some full passes............I see a feature show here w/the 405 boys.............You vs Farmtruck.........
Re: Stroker Hemi combos, ET/power #s [Re: grncpe] #1554962
12/30/13 05:50 PM
12/30/13 05:50 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
[url=http://s823.photobucket.com/user/FabBakers/media/airtime1_zps4c628866.jpg.html][image]http://i823.photobucket.com/albums/zz160/FabBakers/airtime1_zps4c628866.jp
g[/image][/url]
I'm demanding more pictures of this beautiful cuda
Re: Stroker Hemi combos, ET/power #s [Re: Sammy] #1554963
12/30/13 06:53 PM
12/30/13 06:53 PM
mi
dirty magnum Offline
mi
g[/image][/url]
x2
Re: Stroker Hemi combos, ET/power #s [Re: dirty magnum] #1554964
12/30/13 07:04 PM
12/30/13 07:04 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
g[/image][/url]
x2
I had to right click/save when he posted pics of it a while ago. It is nice
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Stroker Hemi combos, ET/power #s [Re: gregsrt] #1554965
12/30/13 07:23 PM
12/30/13 07:23 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Sure!
I only have a few on photobucket... There was a thread on here while I was building it. I think it was SS/DA progress.... Thanks for asking
Re: Stroker Hemi combos, ET/power #s [Re: grncpe] #1554966
12/30/13 11:11 PM
12/30/13 11:11 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Sure!
beautiful fish!
Come on an tease me some more. Awesome is an understatement.
Re: Stroker Hemi combos, ET/power #s [Re: Sammy] #1554967
12/31/13 12:01 AM
12/31/13 12:01 AM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Dont want to mud up this guys thread with my stuff. Here is the link from when I was doing mine. I left out alot of the painting picks because I dont really like showing people how I do some things...just me. https://board.moparts.org/ubbthreads/show...part=1&vc=1
