Re: Stroker Hemi combos, ET/power #s
[Re: 408cuda]
#1554951
12/29/13 01:48 PM
12/29/13 01:48 PM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
505" al KB, 10.71 BDS, 246*/256* roller. 640+ RWHP on pump gas. 68 Dart street/strip car.
Master, again and still
[Re: DaveRS23]
#1554952
12/29/13 02:12 PM
12/29/13 02:12 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Well...I detuned my Hemi for reliability and to be legal Nostalgia Mod Gas....Still 11.6:1 compression, still pump gas friendly, 484 cubes, good flowing heads but more room in them yet maybe 20cfm, good size valves, ported intake...It definitly liked the TR better, but I have an SV1 on the way that should wake it up... Made +750hp Injected with a real cam.... Under carburated and with a very mild cam, and less valve spring pressure, its made 665hp so far with an ignition miss, and a crack in the intake...Had the intake welded up and I think I found the ignition miss...Still tuning it though.
[Re: Dragula]
#1554953
12/29/13 03:45 PM
12/29/13 03:45 PM
Posts: 4,179 California
mickm
California
not the best picture... 540 c.i. 10.3:1, 248/255 - .605/.588 cam, stage V heads and intake, 2 edelbrock 650's. did 712 at 6k, now using that to tear up the rear tires!
[Re: 408cuda]
#1554954
12/29/13 07:32 PM
12/29/13 07:32 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I haven't had this one on the dyno, and only a few times down the track. The entire car is a new build and not dialed in. My Hemi is 572" alum. World block, CP 10.5 pistons, Stage V replacement heads CNC @ MCH. Comp solid roller from Dwayne Porter. The carb is a 4150 race Demon RS for now, and that is where I am looking to make changes. I have a 426- 3 and a Rat Roaster X ram to play with in the future. Not pushing the car hard at all, short shifting about 6,000. Have three passes with best of 6.13 @ 113.3 mph. Running pump gas. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1554955
12/29/13 09:20 PM
12/29/13 09:20 PM
Posts: 311 Kingsville, Md
grncpe
Kingsville, Md
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow 415@800 lift. 760,740 284@.50 roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run.
[Re: 408cuda]
#1554957
12/30/13 08:48 AM
12/30/13 08:48 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. 853hp@5800, 818ftlbs@4800. Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at 10.74@108. Dave
[Re: grncpe]
#1554959
12/30/13 09:59 AM
12/30/13 09:59 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow [Email]415@800[/Email] lift. 760,740 [Email]284@.50[/Email] roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run. [url=http://s823.photobucket.com/user/FabBakers/media/DSC01727_zps487fa57b.jpg.html]
Now thats tuff !
Here's mine - will be in at around 3500lbs. Made 845HP/770TQ, I hope I can go as fast as you have
Hemi mega block 4.5" bore - o-ringed 4.5" Bryant crank Saenz 7.1" rods 11:1 Diamond pistons - coated tops/skirts Sealed Power rings ARP rod, crank, head studs, oil pan studs, flywheel bolts Bullet roller 752/684" lift 270/280 @ .050" 112 & Isky Red Zone Xtreme EZ roller lifters Indy Legend heads ported 420 cfm Stage V rollers MSD dist/box/crank trigger Indy 426-4 4500 intake/have a 4500 Barton intake as well Pro systems 1150 Electric water pump Milodon ext dual line swinging pickup and pump 727 with all the good gear Ultimate Convertor 9" 4.11s
[Re: 408cuda]
#1554960
12/30/13 05:27 PM
12/30/13 05:27 PM
mickm
California
Awesome iron. Some quality hot rods for sure.
My build is much like Mickm, 520-540ish Stage V street/strip 4 speed.
Have you had yours to the strip at all Mick?
Thanks guys, keep em coming. Winter here is looong!
no, haven't made it yet. dealing with a bunch of issues, most notably an ignition system that either misses badly near the rev limit, or has no rev limit.
hopefully this spring/summer.
[Re: quickd100]
#1554961
12/30/13 05:35 PM
12/30/13 05:35 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. [Email]853hp@5800[/Email], [Email]818ftlbs@4800.[/Email] Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at [Email]10.74@108.[/Email] Dave
This is too cool right there..............hopefully you can get the damage fixed and get some full passes............I see a feature show here w/the 405 boys.............You vs Farmtruck.........
[Re: grncpe]
#1554962
12/30/13 05:50 PM
12/30/13 05:50 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
[url=http://s823.photobucket.com/user/FabBakers/media/airtime1_zps4c628866.jpg.html][image]http://i823.photobucket.com/albums/zz160/FabBakers/airtime1_zps4c628866.jp
g[/image][/url]
I'm demanding more pictures of this beautiful cuda
[Re: Sammy]
#1554963
12/30/13 06:53 PM
12/30/13 06:53 PM
Posts: 167 mi
dirty magnum
mi
g[/image][/url]
x2
[Re: dirty magnum]
#1554964
12/30/13 07:04 PM
12/30/13 07:04 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
g[/image][/url]
x2
I had to right click/save when he posted pics of it a while ago. It is nice
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: grncpe]
#1554966
12/30/13 11:11 PM
12/30/13 11:11 PM
Sammy
Wind Gap,Pa.
Sure!
I only have a few on photobucket... There was a thread on here while I was building it. I think it was SS/DA progress.... Thanks for asking
beautiful fish! Come on an tease me some more. Awesome is an understatement.
