Re: Stroker Hemi combos, ET/power #s
[Re: 408cuda]
#1554951
12/29/13 01:48 PM
12/29/13 01:48 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
505" al KB, 10.71 BDS, 246*/256* roller. 640+ RWHP on pump gas. 68 Dart street/strip car.
Master, again and still
[Re: DaveRS23]
#1554952
12/29/13 02:12 PM
12/29/13 02:12 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Well...I detuned my Hemi for reliability and to be legal Nostalgia Mod Gas....Still 11.6:1 compression, still pump gas friendly, 484 cubes, good flowing heads but more room in them yet maybe 20cfm, good size valves, ported intake...It definitly liked the TR better, but I have an SV1 on the way that should wake it up... Made +750hp Injected with a real cam.... Under carburated and with a very mild cam, and less valve spring pressure, its made 665hp so far with an ignition miss, and a crack in the intake...Had the intake welded up and I think I found the ignition miss...Still tuning it though.
[Re: Dragula]
#1554953
12/29/13 03:45 PM
12/29/13 03:45 PM
Posts: 4,179 California
mickm
California
not the best picture... 540 c.i. 10.3:1, 248/255 - .605/.588 cam, stage V heads and intake, 2 edelbrock 650's. did 712 at 6k, now using that to tear up the rear tires!
[Re: 408cuda]
#1554954
12/29/13 07:32 PM
12/29/13 07:32 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I haven't had this one on the dyno, and only a few times down the track. The entire car is a new build and not dialed in. My Hemi is 572" alum. World block, CP 10.5 pistons, Stage V replacement heads CNC @ MCH. Comp solid roller from Dwayne Porter. The carb is a 4150 race Demon RS for now, and that is where I am looking to make changes. I have a 426- 3 and a Rat Roaster X ram to play with in the future. Not pushing the car hard at all, short shifting about 6,000. Have three passes with best of 6.13 @ 113.3 mph. Running pump gas. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1554955
12/29/13 09:20 PM
12/29/13 09:20 PM
Posts: 311 Kingsville, Md
grncpe
Kingsville, Md
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow 415@800 lift. 760,740 284@.50 roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run.
[Re: 408cuda]
#1554957
12/30/13 08:48 AM
12/30/13 08:48 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. 853hp@5800, 818ftlbs@4800. Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at 10.74@108. Dave
[Re: grncpe]
#1554959
12/30/13 09:59 AM
12/30/13 09:59 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Mine is 588" 4.5 bore, 4.625 stroke. mopar ported heads, flow [Email]415@800[/Email] lift. 760,740 [Email]284@.50[/Email] roller. 12to1 comp. potrted stage V intake, 2 800 cfm afb's Made 836hp @6700, 730tq @ 5300, My car is all steel,full interior on a 10" tire, & leafs. very nose heavy. so far 1.27 60' 9.53@ 142mph. still not a stellar run. [url=http://s823.photobucket.com/user/FabBakers/media/DSC01727_zps487fa57b.jpg.html]
Now thats tuff !
Here's mine - will be in at around 3500lbs. Made 845HP/770TQ, I hope I can go as fast as you have
Hemi mega block 4.5" bore - o-ringed 4.5" Bryant crank Saenz 7.1" rods 11:1 Diamond pistons - coated tops/skirts Sealed Power rings ARP rod, crank, head studs, oil pan studs, flywheel bolts Bullet roller 752/684" lift 270/280 @ .050" 112 & Isky Red Zone Xtreme EZ roller lifters Indy Legend heads ported 420 cfm Stage V rollers MSD dist/box/crank trigger Indy 426-4 4500 intake/have a 4500 Barton intake as well Pro systems 1150 Electric water pump Milodon ext dual line swinging pickup and pump 727 with all the good gear Ultimate Convertor 9" 4.11s
[Re: 408cuda]
#1554960
12/30/13 05:27 PM
12/30/13 05:27 PM
mickm
California
Awesome iron. Some quality hot rods for sure.
My build is much like Mickm, 520-540ish Stage V street/strip 4 speed.
Have you had yours to the strip at all Mick?
Thanks guys, keep em coming. Winter here is looong!
no, haven't made it yet. dealing with a bunch of issues, most notably an ignition system that either misses badly near the rev limit, or has no rev limit.
hopefully this spring/summer.
[Re: quickd100]
#1554961
12/30/13 05:35 PM
12/30/13 05:35 PM
Thumperdart
State of confusion
605 Hemi, MP block, Indy rotating assembly kit, Indy 426SR heads, Bullet custom solid roller, .767/.676, 288/292, 113 centerline. Weiand tunnelram, 2 850 thermoquads, 12 quart pan,Milodon dual line system. [Email]853hp@5800[/Email], [Email]818ftlbs@4800.[/Email] Performance?, best 60ft was a 1.45 spinning, haven't had a clean full 1/4 pass, last pass bent framerails on launch went into chassis shake and had to drop the throttle just past 1/8 mark, coasted through at [Email]10.74@108.[/Email] Dave
This is too cool right there..............hopefully you can get the damage fixed and get some full passes............I see a feature show here w/the 405 boys.............You vs Farmtruck.........
[Re: grncpe]
#1554962
12/30/13 05:50 PM
12/30/13 05:50 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
[url=http://s823.photobucket.com/user/FabBakers/media/airtime1_zps4c628866.jpg.html][image]http://i823.photobucket.com/albums/zz160/FabBakers/airtime1_zps4c628866.jp
g[/image][/url]
I'm demanding more pictures of this beautiful cuda
[Re: Sammy]
#1554963
12/30/13 06:53 PM
12/30/13 06:53 PM
Posts: 167 mi
dirty magnum
mi
g[/image][/url]
x2
[Re: dirty magnum]
#1554964
12/30/13 07:04 PM
12/30/13 07:04 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
g[/image][/url]
x2
I had to right click/save when he posted pics of it a while ago. It is nice
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: grncpe]
#1554966
12/30/13 11:11 PM
12/30/13 11:11 PM
Sammy
Wind Gap,Pa.
Sure!
I only have a few on photobucket... There was a thread on here while I was building it. I think it was SS/DA progress.... Thanks for asking
beautiful fish! Come on an tease me some more. Awesome is an understatement.
[Re: 408cuda]
#1554968
12/31/13 02:34 PM
12/31/13 02:34 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
572" hemi, KB block, MP heads CNC'd by MCH. 11:1 compression for pump gas. Solid roller spec'd by Dwayne Porter...mild grind to be easy on parts. Ray Barton single 4500 intake, 1200 pro systems dominator. 727, custom 5k stall, 4.10 gear, 295-65 drag radials. Cal-tracs rear suspension. 3800+ lb. '70 cuda, footbraked, full interior, street car. 9.54 at 140.4 mph, 1.320 sixty foot. All motor.
[Re: an8sec70cuda]
#1554969
12/31/13 02:37 PM
12/31/13 02:37 PM
an8sec70cuda
[Re: 408cuda]
#1554970
12/31/13 03:45 PM
12/31/13 03:45 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine is an all aluminum 496 Indy Maxx block.On the dyno it made 974 hp @ 6500 on 10 pounds of boost...got it home jetted it down 2 sizes and changed to 10 percent over and it made 14 pounds of boost so it should be around 1100 hp. 4.25 gun drilled callies xl crank. Oliver rods 4.31 Ross Pistons/8.2 compression Indy Legend-1 CNC heads Dick Landy Rockers Bullet/Morris roller cam Intake .707/272@.050 Ex .684/280@.050 Comp lifters Smith Bros push rods Charlies pan with swinging pickup Milidon pump and single line cover Supercharger USA Teflon stripped 10-71 2 Quick Fuel 1050 dominators Mezeire high volume water pump PTC Spragless convertor Before install...... In the car.....
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Dragula]
#1554975
01/07/14 03:34 PM
01/07/14 03:34 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Awesome thread. Who has the biggest cu in HEMI? Who's is making the most power? My KB HEMI is far from finished so i must live thru all of you for now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
