Re: paint on the switch panel?? 69 RR
[Re: parksr5]
#1553912
12/27/13 06:15 PM
12/27/13 06:15 PM
Posts: 1,775 Marion, SC USA
69RR383
Marion, SC USA
A paint pen hands down is the easiest, cleanest way to paint the letters. I just did mine about two years ago and it is very easy compared to a brush or anything else I've tried to use in the past. I got mine at a local craft type store. You break the seal on the pen and depress the tip and paint starts to flow. It was very easy to get the paint to flow to where it did not leave any marks. You still have to be a little careful but it is 10 times easier than using a brush.
[Re: 68KillerBee]
#1553913
12/27/13 06:30 PM
12/27/13 06:30 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
Pencil eraser works decent. Then I got a set of these from Michaels and they worked perfectly. Just barely put any white paint on it and dab it a few times until its as bright white as you want it.
Another vote for the pencil eraser. I used a new pencil with a perfect eraser. Spread a little Testors model paint on cardboard, and lightly daubed the eraser in it, then wiped the excess until there was just a faint film of paint on the eraser, then started daubing my letters.
It's a no-brainer, very cheap and easy, and the results are fantastic.
