paint on the switch panel?? 69 RR #1553907
12/27/13 02:56 AM
12/27/13 02:56 AM
Oh
His and Her 69's Offline OP
Oh
I am getting ready to paint my switch panel on my 69 RR and will spray the black on but what is the neatest, cleanest way to paint the lettering and surrounds white again???? I have seen them done with a brush and they usually leave brush strokes or get it on the edges.
I was thinking a sponge, maybe some type of a roller or ??? to get the best looking job.
Thanks for any Help on this.
Dash is painted and I need to get it put back together soon.
David
Re: paint on the switch panel?? 69 RR [Re: His and Her 69's] #1553908
12/27/13 04:26 AM
12/27/13 04:26 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A brush is OK, but you use the side of it as opposed to the point, and don't load the bristles with paint. Can also be done with an object like the eraser of a pencil (tamping the paint on). Main thing is to not have any "spider webs" or too much/too thin paint.
Re: paint on the switch panel?? 69 RR [Re: topside] #1553909
12/27/13 02:43 PM
12/27/13 02:43 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
A paint pen hands down is the easiest, cleanest way to paint the letters. I just did mine about two years ago and it is very easy compared to a brush or anything else I've tried to use in the past. I got mine at a local craft type store. You break the seal on the pen and depress the tip and paint starts to flow. It was very easy to get the paint to flow to where it did not leave any marks. You still have to be a little careful but it is 10 times easier than using a brush.
Re: paint on the switch panel?? 69 RR [Re: parksr5] #1553910
12/27/13 04:27 PM
12/27/13 04:27 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Pencil eraser works decent. Then I got a set of these from Michaels and they worked perfectly. Just barely put any white paint on it and dab it a few times until its as bright white as you want it.
Re: paint on the switch panel?? 69 RR [Re: His and Her 69's] #1553911
12/27/13 04:50 PM
12/27/13 04:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
David I went to a good hobby/craft store and bought some really good, fine paint brushes and Testor model paint and took my time. An Exacto knife or push-pin to clean up any mistakes and for me a magnifing glass , no coffee or Red Bull and you can do it, I know you can
Re: paint on the switch panel?? 69 RR [Re: parksr5] #1553912
12/27/13 06:15 PM
12/27/13 06:15 PM
Marion, SC USA
69RR383 Offline
69RR383  Offline
Marion, SC USA
Re: paint on the switch panel?? 69 RR [Re: 68KillerBee] #1553913
12/27/13 06:30 PM
12/27/13 06:30 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Another vote for the pencil eraser. I used a new pencil with a perfect eraser. Spread a little Testors model paint on cardboard, and lightly daubed the eraser in it, then wiped the excess until there was just a faint film of paint on the eraser, then started daubing my letters.
It's a no-brainer, very cheap and easy, and the results are fantastic.
Re: paint on the switch panel?? 69 RR [Re: 68KillerBee] #1553914
12/27/13 08:00 PM
12/27/13 08:00 PM
Vancouver,WA
70b5bird Offline
70b5bird  Offline
Vancouver,WA
X 2 for the eraser
Re: paint on the switch panel?? 69 RR [Re: 70b5bird] #1553915
12/27/13 08:10 PM
12/27/13 08:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The paint pen works great for plastic pieces with well defined and sharp edges. I tried it on my Dart gauge faces that have a rounded stamping and the paint ran off the edge.
You can go over the letters multiple times if you need to. So don't load the paint on all at once.
Re: paint on the switch panel?? 69 RR [Re: burdar] #1553916
12/29/13 04:16 AM
12/29/13 04:16 AM
Oh
Oh
Thanks For All the GOOD Ideas Guys.
I found a spare switch panel that I blasted up also and will practice on that one first. I have all the items that was suggested so it should be easy enough.
Also Mike I too have to use my glasses for this job. It is terrible getting old. Ha Ha
Thanks Again, David
Re: paint on the switch panel?? 69 RR [Re: His and Her 69's] #1553917
12/29/13 11:46 AM
12/29/13 11:46 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i used a toothpick. i know, i know. it was handy and worked just fine.
