Stroker kits & who would you use & not use.?? #1553090
12/25/13 07:04 PM
12/25/13 07:04 PM
Maryville tn
67coronetman Offline OP
Maryville tn
So what would you say....
1. 440 Source.
2. Mancini.
3. Muscle motors.
And so on just to name a few i know there are other so is there really a clear winner or are they all made by one or two suppliers then they put there names on them.
Old car are me......
Re: Stroker kits & who would you use & not use.?? [Re: 67coronetman] #1553091
12/25/13 07:21 PM
12/25/13 07:21 PM
okla.
sam64 Offline
sam64  Offline
okla.
take your pick,i have 2 440 source motors right now.470 and 512 lowdecks.i also used a ohio crankshaft kit in a small block.i have a 499 lowdeck with an eagle kit in it but it is just hangin on an engine stand lookin for a new owner.
Re: Stroker kits & who would you use & not use.?? [Re: sam64] #1553092
12/25/13 08:10 PM
12/25/13 08:10 PM
Maryville tn
Maryville tn
What do you want for the 499 Lowdeck....
Re: Stroker kits & who would you use & not use.?? [Re: 67coronetman] #1553093
12/25/13 08:41 PM
12/25/13 08:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just call Nick at www.compu-flow.com
Nick will set you up with a total package that will exceed your expectations.
Gus
64 Plymouth Savoy
Dana 60
Re: Stroker kits & who would you use & not use.?? [Re: fourgearsavoy] #1553094
12/25/13 09:30 PM
12/25/13 09:30 PM
okla.
sam64 Offline
sam64  Offline
okla.
Mine[499] was built by Pete at Best Machine.
Re: Stroker kits & who would you use & not use.?? [Re: sam64] #1553095
12/25/13 10:13 PM
12/25/13 10:13 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Ohio Crank
Master, again and still
Re: Stroker kits & who would you use & not use.?? [Re: sam64] #1553096
12/25/13 10:15 PM
12/25/13 10:15 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
nick is the man I have used 4 of his this year 2 hemis 500 cubs and 2 520's
http://www.compu-flow.com/
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Stroker kits & who would you use & not use.?? [Re: 1969gtx] #1553097
12/26/13 12:22 AM
12/26/13 12:22 AM
Maryville tn
Maryville tn
I will look into what Nick offers...
Re: Stroker kits & who would you use & not use.?? [Re: 67coronetman] #1553098
12/26/13 01:44 AM
12/26/13 01:44 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Used an Eagle kit from Muscle Motors and One from 440 Source, no problems with either.
The only Carbs I care about are under the hood!
Re: Stroker kits & who would you use & not use.?? [Re: Azzkikrcuda] #1553099
12/26/13 06:36 AM
12/26/13 06:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I built my 493 with a 440Source kit. I checked everything after I got the kt and found everything within specs. I did a few mods myself but nothing that was a problem. Biggest thing I had was the piston pins are all tight in the rods but it was no big deal to me as I like to set the specs where I want them and all I did was hone the rod bushings to get the spec where I wanted them. Its been in my 63 since 2011 with alot of street miles and a few passes down the track. It has been flawless with zero trouble for the 2-1/2 years I have been driving it with the 493 in it. Ron
Re: Stroker kits & who would you use & not use.?? [Re: 383man] #1553100
12/26/13 07:48 AM
12/26/13 07:48 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I carefully measured everything in the 512 440Source stroker kit, and found all to be good.
Same here, a few piston pins were a little tight, but no big deal.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: Stroker kits & who would you use & not use.?? [Re: 383man] #1553101
12/26/13 10:31 AM
12/26/13 10:31 AM
Maryville tn
Maryville tn
Never hurts to ask from all of you who have used the kits before to find out what is good & what is having trouble...
Thanks for the advise..
Re: Stroker kits & who would you use & not use.?? [Re: 67coronetman] #1553102
12/27/13 01:39 AM
12/27/13 01:39 AM
I make my own stroker kits, I use Ohio Crankshaft Forged steel cranks, imported from China BB Chevy sytle long H beam forged steel rods, I use custom made or shelf American made brand (Ross,Diamond, Kieth Black Icon) pistons, rings and bearings I have all the clearances set for those parts by a really good machine shop and I then assembled and check the clearances and finish blueprinting the motors myself You can do the same thing yourself
Re: Stroker kits & who would you use & not use.?? [Re: Cab_Burge] #1553103
12/27/13 11:07 AM
12/27/13 11:07 AM
Maryville tn
Maryville tn
I am doing more or less the same as you i already have a 4.15 stroker crank & H-Beam rods i still need the pistons & all the other stuff like bearing & so on...
