Stroker kits & who would you use & not use.??
#1553090
12/25/13 07:04 PM
12/25/13 07:04 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
So what would you say.... 1. 440 Source. 2. Mancini. 3. Muscle motors. And so on just to name a few i know there are other so is there really a clear winner or are they all made by one or two suppliers then they put there names on them.
Old car are me......
Re: Stroker kits & who would you use & not use.??
[Re: sam64]
#1553092
12/25/13 08:10 PM
12/25/13 08:10 PM
67coronetman
Maryville tn
What do you want for the 499 Lowdeck....
[Re: 67coronetman]
#1553093
12/25/13 08:41 PM
12/25/13 08:41 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Just call Nick at www.compu-flow.comNick will set you up with a total package that will exceed your expectations. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sam64]
#1553096
12/25/13 10:15 PM
12/25/13 10:15 PM
Posts: 643 southern conn
1969gtx
southern conn
nick is the man I have used 4 of his this year 2 hemis 500 cubs and 2 520's http://www.compu-flow.com/
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 67coronetman]
#1553098
12/26/13 01:44 AM
12/26/13 01:44 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Used an Eagle kit from Muscle Motors and One from 440 Source, no problems with either.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#1553099
12/26/13 06:36 AM
12/26/13 06:36 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I built my 493 with a 440Source kit. I checked everything after I got the kt and found everything within specs. I did a few mods myself but nothing that was a problem. Biggest thing I had was the piston pins are all tight in the rods but it was no big deal to me as I like to set the specs where I want them and all I did was hone the rod bushings to get the spec where I wanted them. Its been in my 63 since 2011 with alot of street miles and a few passes down the track. It has been flawless with zero trouble for the 2-1/2 years I have been driving it with the 493 in it. Ron
[Re: 383man]
#1553100
12/26/13 07:48 AM
12/26/13 07:48 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
I carefully measured everything in the 512 440Source stroker kit, and found all to be good. Same here, a few piston pins were a little tight, but no big deal.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: 383man]
#1553101
12/26/13 10:31 AM
12/26/13 10:31 AM
67coronetman
Maryville tn
Never hurts to ask from all of you who have used the kits before to find out what is good & what is having trouble...
Thanks for the advise..
