GOOD SOLVENT IN CALIFORNIA.......................... #1549890
12/18/13 05:53 PM
12/18/13 05:53 PM
State of confusion
Thumperdart Offline OP
State of confusion
What`s a good solvent that actually cleans out here cos the new and UNimproved stuff doesn`t clean and leaves a black oily residual........... Thankxxxx...............
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549891
12/18/13 06:20 PM
12/18/13 06:20 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Tequila.....Although, its also good to drink as well, so that makes it Ca approved. The only draw backs are the side effects...
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549892
12/18/13 06:24 PM
12/18/13 06:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can you buy mineral spirits at the paint store?
If so that is the best solvent to clean parts with, by far.
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Dragula] #1549893
12/18/13 06:39 PM
12/18/13 06:39 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
side effects?
i cant remember any side effects of any tequila usage,not realy sure how i got home after usage and not realy sure who that lady was and realy not sure where the hangover came from
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: 1Fast340] #1549894
12/18/13 06:45 PM
12/18/13 06:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Spit and Dawn dish soap. Is that still legal out there?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Challenger 1] #1549895
12/18/13 06:45 PM
12/18/13 06:45 PM
State of confusion
State of confusion
I`m posting for a friend but I`d imagine he`s been that route however tonight he`ll check this out and maybe post........thankxxx.... NOW, as far as tequila goes, all bets are off and I`ve actually woke up in jail wondering what the hell I did and hoping I didn`t injure or kill someone........Not good..............
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549896
12/18/13 07:17 PM
12/18/13 07:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Dominic, I went to a water based solution about 6 months ago, when my solvent based Safety clean parts washer finally gave out. The key is heat. Went with "Ozzy Juice" SW-3 truck grade degreasing solvent ( NAPA store ). Since my cleaning tank isn't heated and heated tanks are upwords of 1K, I went to Walmart and bought a $15 hot plate. Fabed up a mount so that the hot plate sits up against the bottom of my solvent tank. Takes about 15 minutes for my tank ( 5 gallons ) to get up to about 130 degrees. At that temp, cuts grease every bit as good as solvent based stuff. On the down side, once you clean a metal part, it will rust pretty quick if you don't WD-40 it right after it dries. Stuff will even start to strip paint if you leave the part in long enough.
Fastest 300
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549897
12/18/13 09:13 PM
12/18/13 09:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Mineral spirits (paint thinner) is what I use, it doesn't clean as well as it did many years ago but still does an acceptable job for me.
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: John_Kunkel] #1549898
12/18/13 09:30 PM
12/18/13 09:30 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: pittsburghracer] #1549899
12/18/13 10:09 PM
12/18/13 10:09 PM
n h
sawduster Offline
sawduster  Offline
n h
do you have to heat the PSC-1000 ?
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549900
12/18/13 10:09 PM
12/18/13 10:09 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think it is just LA county the good stuff is band.. you can get what ever you want in the other countys...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: WHITEDART] #1549901
12/18/13 10:13 PM
12/18/13 10:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We had great results with Ozzy Juice as well when I was in Cali. It does have to be heated however due to it being made up of microbes.
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Al_Alguire] #1549902
12/18/13 10:16 PM
12/18/13 10:16 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
HUH
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: sawduster] #1549903
12/18/13 10:25 PM
12/18/13 10:25 PM
PA.
"Little"John
"Little"John
PA.
No.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: pittsburghracer] #1549904
12/18/13 10:31 PM
12/18/13 10:31 PM
State of confusion
State of confusion
Thankxxx guys.............I`ll pass this on or George will check it out here............
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549905
12/18/13 10:47 PM
12/18/13 10:47 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Dom, I am not sure if they carry it in Kallyfornia, but Graingers use to have a Graymills product I used a lot. It was called Agitene, and Super Agitene solvent. It had higher flash points, and at one time had lanolin in it even, to help your hands, as well as a anti flash rust agent. Check your local Grainger to see.
Also ZEP products. Usually they have a lot of commercial fluids. They have always had a good product, and usually have distribution in larger cities.
Neither of these two are cheap, but usually real good stuff. Good luck..
RIP Monte Smith
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: Thumperdart] #1549906
12/18/13 11:10 PM
12/18/13 11:10 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We use Crystal Simple Green at work. Does a very good job of cleaning stuff.
Nautilus Racing-
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: CompWedgeEngines] #1549907
12/18/13 11:34 PM
12/18/13 11:34 PM
State of confusion
State of confusion
Thankxxx again guys............. I`ll pass this on.........
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: WHITEDART] #1549908
12/19/13 01:03 AM
12/19/13 01:03 AM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Nope. Anywhere in the Southern California Air Quality Managment District, anything but an approved solvent ( Q-sol, which is supplied by Safteykleen, or a waterbased cleaner) is illegal. I was fined 1800.00 a few years ago for still using a mineral spirits based solvent. Safteykleen will not even sell any mineral based solvent in this area.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: GOOD SOLVENT IN CALIFORNIA.......................... [Re: zzyzxpat] #1549909
12/19/13 02:16 AM
12/19/13 02:16 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I remember the old safety kleen solvent "20years ago" would clean anything and if you had a cut on your hand it would sting like hell! Your hands would turn white cause it would strip the oils. We didn't use no stinking gloves like we do today and we needed them more back then. Heck, I think Italian salad dressing would work better to clean parts than the New "improved safe" diluted mineral spirits you can buy now They are engineering common sense out of society and trying to save us from ourselves sorry rant over
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
