Re: GOOD SOLVENT IN CALIFORNIA..........................
[Re: Dragula]
#1549893
12/18/13 06:39 PM
12/18/13 06:39 PM
Posts: 2,578 sweden
1Fast340
sweden
Tequila.....Although, its also good to drink as well, so that makes it Ca approved. The only draw backs are the side effects...
side effects? i cant remember any side effects of any tequila usage,not realy sure how i got home after usage and not realy sure who that lady was and realy not sure where the hangover came from
[Re: Thumperdart]
#1549897
12/18/13 09:13 PM
12/18/13 09:13 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Mineral spirits (paint thinner) is what I use, it doesn't clean as well as it did many years ago but still does an acceptable job for me.
[Re: WHITEDART]
#1549901
12/18/13 10:13 PM
12/18/13 10:13 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
We had great results with Ozzy Juice as well when I was in Cali. It does have to be heated however due to it being made up of microbes.
[Re: Thumperdart]
#1549905
12/18/13 10:47 PM
12/18/13 10:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Dom, I am not sure if they carry it in Kallyfornia, but Graingers use to have a Graymills product I used a lot. It was called Agitene, and Super Agitene solvent. It had higher flash points, and at one time had lanolin in it even, to help your hands, as well as a anti flash rust agent. Check your local Grainger to see. Also ZEP products. Usually they have a lot of commercial fluids. They have always had a good product, and usually have distribution in larger cities. Neither of these two are cheap, but usually real good stuff. Good luck..
RIP Monte Smith
[Re: Thumperdart]
#1549906
12/18/13 11:10 PM
12/18/13 11:10 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We use Crystal Simple Green at work. Does a very good job of cleaning stuff.
[Re: WHITEDART]
#1549908
12/19/13 01:03 AM
12/19/13 01:03 AM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Nope. Anywhere in the Southern California Air Quality Managment District, anything but an approved solvent ( Q-sol, which is supplied by Safteykleen, or a waterbased cleaner) is illegal. I was fined 1800.00 a few years ago for still using a mineral spirits based solvent. Safteykleen will not even sell any mineral based solvent in this area.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
