Re: Aftermarket auto shifter in stock b body console?
[Re: 1cuda]
#1549751
12/18/13 01:28 PM
12/18/13 01:28 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
why dont you try and fit a 70 onwards slapstick shifter-they ratchet and look better than any aftermarket shifter-you can even get an auto pistolgrip handle mechanism from gunslinger-it`s in the mopar theme and great to use. all the best frank http://www.gunslingershifters.com/70gunslingershifter.htm
I have used a 70 e-body slap stick. The arm off the vertical rod needs to be effectively shortened (hole to hole distance), I believe it is from 1.5" to 1.25" (this is from memory as I haven't done this in a while and this was on an A-body, but I believe those pieces may have the same levers). I also have the taller version of the slapstick (longer handle) from a later B...
No pictures on this computer, though.
[Re: Burlapen]
#1549755
12/20/13 03:48 PM
12/20/13 03:48 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Sorry if this sounds a little bone head...but why can't you just put 1" square tube on the fore and aft brackets and lift the entire console up and stuff the shifter you want...inside
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: StealthWedge67]
#1549757
12/24/13 08:24 PM
12/24/13 08:24 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
Not sure how many mods this guy did but he fit a B&M in
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
