Aftermarket auto shifter in stock b body console? #1549749
12/18/13 04:41 AM
12/18/13 04:41 AM
Clovis, Ca
Burlapen Offline OP
Burlapen  Offline OP
Clovis, Ca
I have tried a few out, they all seem to be too tall. Not the handle but the actual mechanism won't allow the console to sit all the way down to the floor. Does anyone know of one that works? This is on a 67 satellite btw. Thanks.
Re: Aftermarket auto shifter in stock b body console? [Re: Burlapen] #1549750
12/18/13 07:53 AM
12/18/13 07:53 AM
western australia
1cuda Offline
1cuda  Offline
western australia
why dont you try and fit a 70 onwards slapstick shifter-they ratchet and look better than any aftermarket shifter-you can even get an auto pistolgrip handle mechanism from gunslinger-it`s in the mopar theme and great to use.
all the best
frank
http://www.gunslingershifters.com/70gunslingershifter.htm
Re: Aftermarket auto shifter in stock b body console? [Re: 1cuda] #1549751
12/18/13 01:28 PM
12/18/13 01:28 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
all the best
frank
I have used a 70 e-body slap stick. The arm off the vertical rod needs to be effectively shortened (hole to hole distance), I believe it is from 1.5" to 1.25" (this is from memory as I haven't done this in a while and this was on an A-body, but I believe those pieces may have the same levers). I also have the taller version of the slapstick (longer handle) from a later B...
No pictures on this computer, though.
Re: Aftermarket auto shifter in stock b body console? [Re: Jim_Lusk] #1549752
12/18/13 04:06 PM
12/18/13 04:06 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I don't know if this will help as I do not know how the dimensions of your console compare to the 68-70 console however; I ran a Hurst Promatic 2 in a 68-70 console for years and the fit was perfect.
Re: Aftermarket auto shifter in stock b body console? [Re: parksr5] #1549753
12/18/13 04:08 PM
12/18/13 04:08 PM
Boston, MA
crocha617 Offline
crocha617  Offline
Boston, MA
A guy I know has a new style pistol grip setup in the works. It should be available really soon. It works with the stock floor shifter.
Re: Aftermarket auto shifter in stock b body console? [Re: parksr5] #1549754
12/18/13 04:14 PM
12/18/13 04:14 PM
Clovis, Ca
Burlapen Offline OP
Burlapen  Offline OP
Clovis, Ca
I believe it is exactly the same as a 68-70 console. I thought about the slapstick but really wanted to stay away from all the linkage and just use a simple cable. I have the hurst V-matrix which is a bit too tall. Maybe the pro matic has a shorter body??
Re: Aftermarket auto shifter in stock b body console? [Re: Burlapen] #1549755
12/20/13 03:48 PM
12/20/13 03:48 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Sorry if this sounds a little bone head...but why can't you just put 1" square tube on the fore and aft brackets and lift the entire console up and stuff the shifter you want...inside
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Aftermarket auto shifter in stock b body console? [Re: Pyper70] #1549756
12/24/13 06:19 PM
12/24/13 06:19 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Thats what I would look at.
Re: Aftermarket auto shifter in stock b body console? [Re: StealthWedge67] #1549757
12/24/13 08:24 PM
12/24/13 08:24 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Not sure how many mods this guy did but he fit a B&M in
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
