Page 1 of 3 1 2 3
Cheap Headers #1549587
12/18/13 12:36 AM
12/18/13 12:36 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Does anyone make a cheap (around $165) full length header for a 1969 B body with big block AND...power steering.
Re: Cheap Headers [Re: johnfin] #1549588
12/18/13 12:53 AM
12/18/13 12:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Where did the $165 number come from? The contents of the kids piggy bank?
GOOD fitting headers cost more than $165.
Re: Cheap Headers [Re: Kern Dog] #1549589
12/18/13 01:10 AM
12/18/13 01:10 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I looked at sites like Jegs and Summit, they had a few from 139 to 175 so I just piked around 165. Only problem is they wont work with power steering. I have some HP cast exhaust manifolds but dont really want to use them.
Re: Cheap Headers [Re: johnfin] #1549590
12/18/13 01:55 AM
12/18/13 01:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I had Hedmans on my 71 RR 383 with PS. Good fit with no interference problems..
I am truckless..
Re: Cheap Headers [Re: 340SHORTY] #1549591
12/18/13 03:03 AM
12/18/13 03:03 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
They will work with power steering. You may have to make a couple dings for clearance but the cheapies will work. One way is to use a c-clamp with a block of wood on one side so you don't mash them up like with a hammer.
Re: Cheap Headers [Re: johnfin] #1549592
12/18/13 07:29 AM
12/18/13 07:29 AM
Central TX
roe Offline
roe  Offline
Central TX
I used Doug's headers on mine. I was originally looking at the less expensive headers as well. But after comparing them all from Summit brand up to TTI, Dougs were the best all around IMO. They have the same really thick, antiwarp phalanges that the TTI's have, and the same thick gauge steel for the pipes, they fit just as well as the the TTI's, which is miles ahead of the cheaper ones, and go above the suspension unlike the cheapies, they dont hang low and hit/scrape the ground, and they cost significantly less than the TTI's. Install was very easy, unlike the cheaper headers. I didnt have to take any of my suspension apart. I have and automatic with power steering and I didn't have to disconnect any of the steering components. The passenger side went in from the bottom with no problems, and the driver side required loosening the motor mount and slightly elevating that side of the motor with a floor jack and a piece of wood that reached up to the pan rail. I also removed both torsion bars for the install. The extra headache saved by not having to undo the suspension, not having to jack up the passenger side of the motor, not having the suspension travel between the pipes, not having to make a single ding anywhere, and not having to disconnect any of the steering components, etc...saved me tons of time. And as an added bonus I can R&R my mini starter without touching the the headers. I dont know about a stock starter because my mini was already installed before the headers.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Cheap Headers [Re: roe] #1549593
12/18/13 09:50 AM
12/18/13 09:50 AM
jersey
Spaceman Spiff Offline
jersey
I hear blackjack makes a nice fitting cheap header....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Cheap Headers [Re: Spaceman Spiff] #1549594
12/18/13 12:30 PM
12/18/13 12:30 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
According to the Doug's site, cant run them if you have an auto with column shift, which I have.
Re: Cheap Headers [Re: johnfin] #1549595
12/18/13 08:46 PM
12/18/13 08:46 PM
Central TX
roe Offline
roe  Offline
Central TX
Thats what I saw too, when I ordered mine, but was assured by the guy that I ordered from that it would work. And it did, fit like a glove, no problems, no close spots, nada. And I have a column shift auto as well.
Re: Cheap Headers [Re: DaytonaTurbo] #1549596
12/18/13 09:07 PM
12/18/13 09:07 PM
Highland, MI.
Sunroofcuda Online content
Sunroofcuda  Online Content
Highland, MI.
If they are Dynomax, they won't fit with PS.
Re: Cheap Headers [Re: roe] #1549597
12/18/13 09:53 PM
12/18/13 09:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Doug's headers have finger bones?
Don't be the exception.
Re: Cheap Headers [Re: Supercuda] #1549598
12/19/13 01:06 AM
12/19/13 01:06 AM
mi
E
ERAT340 Offline
ERAT340  Offline
E
mi
Dont wanna see DOUGS nameplate in my face when I open the hood.
Re: Cheap Headers [Re: Supercuda] #1549599
12/19/13 01:06 AM
12/19/13 01:06 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Re: Cheap Headers [Re: Supercuda] #1549600
12/19/13 01:21 AM
12/19/13 01:21 AM
Central TX
roe Offline
roe  Offline
Central TX
Re: Cheap Headers [Re: DaytonaTurbo] #1549601
12/19/13 03:43 AM
12/19/13 03:43 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The Summit brand WONT work on a 67 with P.S. This much I know for a fact.
Hooker Comps are less than $100 from that budget (which really isn't one). Be patient and save some coin.
Re: Cheap Headers [Re: johnfin] #1549602
12/19/13 10:18 AM
12/19/13 10:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
These are the Summit racing headers, they fit well and I didn't have to bend or ding anything. Just take your time, get the car up and the engine up and they will go in fine. and it was column shift at the time.
Coming soon!!!!
Re: Cheap Headers [Re: Mr.Yuck] #1549603
12/19/13 10:32 AM
12/19/13 10:32 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Sale your HP manifolds to make up the gap and buy what you want.
Careful, your character's showing!
Re: Cheap Headers [Re: johnfin] #1549604
12/22/13 06:31 AM
12/22/13 06:31 AM
America
bambi Offline
bambi  Offline
America
You are joking, right? WHY? What the hell do you expect to increase? Per dollar wise, Head aches, fitment issues, burnt plug wires, exhaust leaks, starter fitment issues/burn out. SERIOUSLY? What the hell do you expect to increase? What is your primary goal? Do you realize that headers actuall only increase HP by maybe ten or fifteen over stock? and THAT does not include Factory HP manifolds? Factory manifolds are almost as good as headers, with out all the hassles. WHAT on Gods GREEN EARTH makes you want to swap them out for HEADERS? Are you crazy? Seriously. You will never ever ever see any increase on a street motor. You will invite yourself open to a host of problems with headers. WHY? Why would anyone make this boneheaded move? If you want noise, get some Flowmaster Mufflers and be done with it. You can't possibly be serious. READ UP ON IT.
Re: Cheap Headers [Re: johnfin] #1549605
12/22/13 09:30 AM
12/22/13 09:30 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You want to buy "cheap" headers...
Re: Cheap Headers [Re: bambi] #1549606
12/22/13 12:03 PM
12/22/13 12:03 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Why don't you tell us how you really feel.
Page 1 of 3 1 2 3
