Duster/Demon rear wheel width question #1549361
12/17/13 03:23 PM
12/17/13 03:23 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Does anyone know if a 15x9 with 5" backspace fit with the springs in the stock location. I have a 15x8 (not 100% positive it's 8") wheel now with 4-1/8 backspace now. It has 7/8 to the spring now. Assume I use the same tire. I want to verify before I spend the $ for new wheels. Rolled quarter
The tire is a 11.5 x28.0 ET street. 8.6 tread and 11.1 section. The tire section measure 10-5/8 now
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549362
12/17/13 03:37 PM
12/17/13 03:37 PM
Guitar Jones Offline
Well by your figures the math says no. If you have 7/8 of an inch to the spring with a 4 1/8 back space then adding 7/8 of an inch to the back space would hit.
Re: Duster/Demon rear wheel width question [Re: Guitar Jones] #1549363
12/17/13 04:26 PM
12/17/13 04:26 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
My thoughts are I would get half on each side of the tire? Plus not confident increasing the wheel 1 inch will make the section 1 inch wider either. Thoughts?
2021 T/A 392
2020 Hellcat redeye
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549364
12/17/13 04:37 PM
12/17/13 04:37 PM
No, 5" back space is 5" regardless of the wheels width.
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549365
12/17/13 05:04 PM
12/17/13 05:04 PM
if you keep the back spacing the same on both wheels you will increase the wheel width by 1/2 on both the front and back side like you have already pointed out Did you measure both sides? If not you should , it is not uncommon on all types of Unibody Mopars to NOT have the samm clearances on both sides The section width on both sides will increase also By how much I'm not usre of
Re: Duster/Demon rear wheel width question [Re: Cab_Burge] #1549366
12/17/13 05:26 PM
12/17/13 05:26 PM
Look at it like this. A 10" wheel with 5" of backspace will have 5" in front and 5" in back. A 9" wheel with 5" of back space will have 4" in front and 5" in back. 5" of back space is still going to be 5" of back space whether the wheel is 5" or 25" wide.
Re: Duster/Demon rear wheel width question [Re: Guitar Jones] #1549367
12/17/13 06:02 PM
12/17/13 06:02 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Looks like I need to stick with the 8 inch wheel with 4" back space
2021 T/A 392
2020 Hellcat redeye
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549368
12/17/13 07:25 PM
12/17/13 07:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You could always use some 1/2 inch spacers and with same tire and new rim and be close to same clearance as the 4 inch backspace rim. Race or street? My race car had a shinny spring where it would touch from turning corners, never hurt the tire.
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549369
12/17/13 07:58 PM
12/17/13 07:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Do you have any photos of your current setup? The Duster I'm building now is gonna have stock tubs and stock leaf spring location. I'm surprised you have that big 28x11.5 tire in there.
Re: Duster/Demon rear wheel width question [Re: ProSport] #1549370
12/17/13 08:46 PM
12/17/13 08:46 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
my car had the same tire's .
had stock width a-body 8 3/4 with the b-body axle's and drum brakes .
had stock wheel tubs with a 8.5 centerline wheel with 3 3/8 BS .
never hit anything (spring/wheel lip).
that was with SS springs with the front hangers flipped .
ps. it wa the 3 and what ever BS can't remember off the top of my head right now .
brad
Re: Duster/Demon rear wheel width question [Re: ProSport] #1549371
12/17/13 09:08 PM
12/17/13 09:08 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We had 29.5 x 11.5 in our with stock tubs ! It did rub a little on hard turns but only on the springs, we put washers on the studs and all was right !
Re: Duster/Demon rear wheel width question [Re: 70dusterjohn] #1549372
12/17/13 09:22 PM
12/17/13 09:22 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Here are some pictures. Not great. Its a street/strip car. I thought about a 1/4 spacer too.
2021 T/A 392
2020 Hellcat redeye
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549373
12/17/13 09:22 PM
12/17/13 09:22 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
More
2021 T/A 392
2020 Hellcat redeye
Re: Duster/Demon rear wheel width question [Re: moparfan] #1549374
12/17/13 09:36 PM
12/17/13 09:36 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
no problem,just get some tire butter and rub some on......
SFI 25.5 depends,no leak,even at 213 mph....
Re: Duster/Demon rear wheel width question [Re: Guitar Jones] #1549375
12/17/13 10:37 PM
12/17/13 10:37 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
your going to hit.
