Duster/Demon rear wheel width question
#1549361
12/17/13 03:23 PM
12/17/13 03:23 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
Does anyone know if a 15x9 with 5" backspace fit with the springs in the stock location. I have a 15x8 (not 100% positive it's 8") wheel now with 4-1/8 backspace now. It has 7/8 to the spring now. Assume I use the same tire. I want to verify before I spend the $ for new wheels. Rolled quarter
The tire is a 11.5 x28.0 ET street. 8.6 tread and 11.1 section. The tire section measure 10-5/8 now
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
Re: Duster/Demon rear wheel width question
[Re: moparfan]
#1549362
12/17/13 03:37 PM
12/17/13 03:37 PM
Guitar Jones
Well by your figures the math says no. If you have 7/8 of an inch to the spring with a 4 1/8 back space then adding 7/8 of an inch to the back space would hit.
[Re: Guitar Jones]
#1549363
12/17/13 04:26 PM
12/17/13 04:26 PM
moparfan
Marysville Wa
My thoughts are I would get half on each side of the tire? Plus not confident increasing the wheel 1 inch will make the section 1 inch wider either. Thoughts?
[Re: moparfan]
#1549364
12/17/13 04:37 PM
12/17/13 04:37 PM
Guitar Jones
No, 5" back space is 5" regardless of the wheels width.
[Re: Cab_Burge]
#1549366
12/17/13 05:26 PM
12/17/13 05:26 PM
Guitar Jones
if you keep the back spacing the same on both wheels you will increase the wheel width by 1/2 on both the front and back side like you have already pointed out Did you measure both sides? If not you should , it is not uncommon on all types of Unibody Mopars to NOT have the samm clearances on both sides The section width on both sides will increase also By how much I'm not usre of
Look at it like this. A 10" wheel with 5" of backspace will have 5" in front and 5" in back. A 9" wheel with 5" of back space will have 4" in front and 5" in back. 5" of back space is still going to be 5" of back space whether the wheel is 5" or 25" wide.
[Re: Guitar Jones]
#1549367
12/17/13 06:02 PM
12/17/13 06:02 PM
moparfan
Marysville Wa
Looks like I need to stick with the 8 inch wheel with 4" back space
[Re: moparfan]
#1549369
12/17/13 07:58 PM
12/17/13 07:58 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Do you have any photos of your current setup? The Duster I'm building now is gonna have stock tubs and stock leaf spring location. I'm surprised you have that big 28x11.5 tire in there.
[Re: ProSport]
#1549371
12/17/13 09:08 PM
12/17/13 09:08 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
We had 29.5 x 11.5 in our with stock tubs ! It did rub a little on hard turns but only on the springs, we put washers on the studs and all was right !
[Re: 70dusterjohn]
#1549372
12/17/13 09:22 PM
12/17/13 09:22 PM
moparfan
Marysville Wa
Here are some pictures. Not great. Its a street/strip car. I thought about a 1/4 spacer too.
[Re: Guitar Jones]
#1549375
12/17/13 10:37 PM
12/17/13 10:37 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
your going to hit.
