trailer roof #1545073
12/08/13 10:36 AM
12/08/13 10:36 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its time to paint the roof on my race trailer.it its a 1996 haulmark.all around the edges is some kind of silver tape,i dont know if it was added by the previous owner or not.once i get it all scrapped off should i just retape it or is there a ruberized type product i can roll on to seal the edges?
Re: trailer roof [Re: bonefish] #1545074
12/08/13 10:53 AM
12/08/13 10:53 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have used some of the silver tape on my old motor home, its about 3 yrs old and is holding up great. I have both white and silver tape. The silver I bought at a home improvement store and the white came from a RV store. The silver is much cheaper.
Re: trailer roof [Re: bonefish] #1545075
12/08/13 11:09 AM
12/08/13 11:09 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I would just rubber coat it & never look back. I put on 2 coats. No issue's.
Re: trailer roof [Re: bonefish] #1545076
12/08/13 12:00 PM
12/08/13 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I used silicone/rtv and a brush... I bought the tubes
and put it on then brushed it out
Re: trailer roof [Re: rickraw] #1545077
12/08/13 12:04 PM
12/08/13 12:04 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I owned two 1996 Haulmark trailers. One was a 24ft tag then I traded for a 32ft goose. The one thing I liked about them was the continuous sheet aluminum roof. I can't imagine anyone wanting to paint that roof.
This said I can't speak for your trailer which could have some other sheeting on the roof.
If it was painted before and flaking or something I guess you have to consider that also,
Leon
Re: trailer roof [Re: rickraw] #1545078
12/08/13 12:09 PM
12/08/13 12:09 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
a white water base coating is the only real way to do it.. there are many types and brand out there. you want something with a heavy solid .. you can get this one from LOWES/HOMEDEPOT for around 100$.. apply as stated on the bucket......... http://www.google.com/url?sa=t&rct=j...4sg-nR462tXGRSA
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: trailer roof [Re: Leon441] #1545079
12/08/13 12:09 PM
12/08/13 12:09 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Paint something unique on the roof in the event the trailer is ever stolen. Makes it much easier to identify from the air.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: trailer roof [Re: Leon441] #1545080
12/08/13 12:47 PM
12/08/13 12:47 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Leon
the main reason for painting the roof is that it is starting to get some basket ball size spots of surface rust and the tape is starting to break down.plus i would like it to be white,its DARK blue,here in Fla. every little bit of cooling helps.
Re: trailer roof [Re: bonefish] #1545081
12/08/13 12:56 PM
12/08/13 12:56 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
remove all rust before you coat it ..
Re: trailer roof [Re: WHITEDART] #1545082
12/08/13 01:12 PM
12/08/13 01:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just go to home depot and get the white roof sealer stuff it comes in gallon cans. thats what I use.
Re: trailer roof [Re: bonefish] #1545083
12/08/13 01:24 PM
12/08/13 01:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I can't think of anything on the roof of my 97 Haulmark Elite II that would rust? Like Leon's, mine has a single sheet roof and no tape at the seams, just a generous coating of seam sealer. I will say one thing, the roof on the Haulmark is a whole lot sturdier than our 28ft Cargo Mate.
Re: trailer roof [Re: J_BODY] #1545084
12/08/13 01:55 PM
12/08/13 01:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My old Haulmark was a 1 piece alum also.. same as
my current trailer... I use the silicone as I said
Re: trailer roof [Re: J_BODY] #1545085
12/08/13 01:59 PM
12/08/13 01:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
If you decide to coat/paint/seal the roof, remember that preparation is the key!
Get every square inch that is going to lift or flake clean. Kill any rust. get any remaining solid old coat roughed up so the new stuff will stick.
If you just pour on a new coat over the old stuff without prep, the base will still lift and flake.
Re: trailer roof [Re: RodStRace] #1545086
12/08/13 03:32 PM
12/08/13 03:32 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
dont look like alum. to me.must be the economy model.
Re: trailer roof [Re: bonefish] #1545087
12/08/13 03:34 PM
12/08/13 03:34 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
haulmark
Re: trailer roof [Re: bonefish] #1545088
12/08/13 03:37 PM
12/08/13 03:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its metal... sand, prime and paint... I would use
rustoleum
Re: trailer roof [Re: MR_P_BODY] #1545089
12/08/13 04:43 PM
12/08/13 04:43 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
They build them both ways, one piece aluminum, or seamed steel, yours for sure is steel, nothing wrong with that, lot of them around,but yep needs cleaning and coating. About 1k differnece in price when new.
Re: trailer roof [Re: wyoming] #1545090
12/08/13 08:08 PM
12/08/13 08:08 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I think the black streaks you see, would be prevented, with a coating on the raw aluminum. I know my 4926 lets the roof water run down the sides, and that starts the black streaks. I'm coating mine next spring. Also, the cleaners that will remove the black streaks, also remove the oem coating, and you better seal or it becomes even more work.
Re: trailer roof [Re: Leigh] #1545091
12/08/13 10:41 PM
12/08/13 10:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My 28 foot pace arrow has a 1 piece aluminum roof. I went to the local RV store and got a quart of brush on rubber type coating to seal up the front cap and along the edges. As said above, proper prep. will make your repair last for years.
Re: trailer roof [Re: MR_P_BODY] #1545092
12/08/13 11:25 PM
12/08/13 11:25 PM
Lehigh Acres, Florida
rickstershemi Offline
rustoleum
^^^^^^ This, except after sanding I would coat it with a couple of coats of OSPHO and then apply a white rubber roof coating
Rickster
Re: trailer roof [Re: rickstershemi] #1545093
12/09/13 01:14 AM
12/09/13 01:14 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
rustoleum
Rickster
Rickster, what is OSPHO, Never heard of it.
Edit: Its a rust killer. But it is controversial on the clean up before paint.
