Re: trailer roof
[Re: rickraw]
#1545077
12/08/13 12:04 PM
12/08/13 12:04 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I owned two 1996 Haulmark trailers. One was a 24ft tag then I traded for a 32ft goose. The one thing I liked about them was the continuous sheet aluminum roof. I can't imagine anyone wanting to paint that roof.
This said I can't speak for your trailer which could have some other sheeting on the roof.
If it was painted before and flaking or something I guess you have to consider that also,
Leon
Re: trailer roof
[Re: Leon441]
#1545080
12/08/13 12:47 PM
12/08/13 12:47 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Leon
the main reason for painting the roof is that it is starting to get some basket ball size spots of surface rust and the tape is starting to break down.plus i would like it to be white,its DARK blue,here in Fla. every little bit of cooling helps.
Re: trailer roof
[Re: J_BODY]
#1545084
12/08/13 01:55 PM
12/08/13 01:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I can't think of anything on the roof of my 97 Haulmark Elite II that would rust? Like Leon's, mine has a single sheet roof and no tape at the seams, just a generous coating of seam sealer. I will say one thing, the roof on the Haulmark is a whole lot sturdier than our 28ft Cargo Mate.
My old Haulmark was a 1 piece alum also.. same as my current trailer... I use the silicone as I said
Re: trailer roof
[Re: wyoming]
#1545090
12/08/13 08:08 PM
12/08/13 08:08 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
I think the black streaks you see, would be prevented, with a coating on the raw aluminum. I know my 4926 lets the roof water run down the sides, and that starts the black streaks. I'm coating mine next spring. Also, the cleaners that will remove the black streaks, also remove the oem coating, and you better seal or it becomes even more work.
Re: trailer roof
[Re: MR_P_BODY]
#1545092
12/08/13 11:25 PM
12/08/13 11:25 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Its metal... sand, prime and paint... I would use rustoleum
^^^^^^ This, except after sanding I would coat it with a couple of coats of OSPHO and then apply a white rubber roof coating
Rickster
