79 Power Wagon Stalls when put into Gear
#1544001
12/05/13 02:08 PM
12/05/13 02:08 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
79 Power Wagon stalls when I put it into drive. Its a automatic and believe a 360 motor. Bought it for $150 bucks and I use it for in the woods for moving logs. It was running okay 2 years ago somewhat. It starts and idles great. No misses or anything. When you put it in gear it stalls or you really have to feather the throttle and maybe you get it under its own power sometimes then it runs okay. Just alot of stumbling and stalling to get it initially going. I just rebuilt the carb but could not get the what I think is the power valve out/plunger thing in center of carb. That didn't fix it. Then I put on new wires/plugs and that didn't fix it. After I ran it around for a little and checked the tranny fluid I noticed it was low, not on the dipstick. I didn't have any fluid at time to put in so I have to get some. Could this cause it or do you think its something with the fuel air/mixture screws at the bottom base of carb. There are 2 adjustment screws. Also, I can't move the 4 wheel drive shifter at all. Seems as if it is frozen. You should be able to just move it anytime right? Nothing special you have to do to put it in 4 wheel drive or out like step on brake or be moving or anything right?
Wizard
Guns, God, and Country.
U.S. Veteran
Re: 79 Power Wagon Stalls when put into Gear
[Re: Wizard]
#1544002
12/05/13 04:07 PM
12/05/13 04:07 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
Shoot some carb cleaner down the air bleeds. I turn in screws till it stumbles and back out 1.5.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
[Re: d-150]
#1544004
12/05/13 07:06 PM
12/05/13 07:06 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Vacuum leak is also possible.
Make sure the carb is tight to the intake, and check vacuum lines.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1544005
12/05/13 07:34 PM
12/05/13 07:34 PM
Wizard
Dillsburg, PA
Gas is fresh and everything is tight and no vacuum leaks. Possibly the accelerator pump someone else mentioned which I did not replace during the carb rebuild due to I could not get it out of the carb no matter how much I tried. Will have to see if it is shooting gas when I move the linkage and look down into it.
U.S. Veteran
[Re: Wizard]
#1544006
12/05/13 08:16 PM
12/05/13 08:16 PM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Big red flag. Was it squirting fuel before rebuild? And what carb do you have?
[Re: redraptor]
#1544007
12/05/13 08:57 PM
12/05/13 08:57 PM
Wizard
Dillsburg, PA
I don't know if it was squirting fuel before the rebuild. I have a 2 barrel model 2210 or 2245 have to look at box to make sure. What kind of tool do you use to get accelerator pump out of carb? I could not budge it out with a screwdriver I believe and it started to strip.
U.S. Veteran
[Re: redraptor]
#1544009
12/24/13 05:26 PM
12/24/13 05:26 PM
Wizard
Dillsburg, PA
Well, I found out what was causing the problem this past weekend. All it was the little metal part I had on backwards that connects to a 3 1/2 long metal connector that hooks to the throttle. The metal piece that I had on backwards pushes down on a plunger that is on top of the carb.
It was not the accerator pump as that squirts fine. So, didn't have to take the carb back off. Got lucky. Thanks to all who shot some ideas out.
Wizard
U.S. Veteran
