79 Power Wagon Stalls when put into Gear #1544001
12/05/13 02:08 PM
12/05/13 02:08 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
79 Power Wagon stalls when I put it into drive. Its a automatic and believe a 360 motor. Bought it for $150 bucks and I use it for in the woods for moving logs. It was running okay 2 years ago somewhat. It starts and idles great. No misses or anything. When you put it in gear it stalls or you really have to feather the throttle and maybe you get it under its own power sometimes then it runs okay. Just alot of stumbling and stalling to get it initially going. I just rebuilt the carb but could not get the what I think is the power valve out/plunger thing in center of carb. That didn't fix it. Then I put on new wires/plugs and that didn't fix it. After I ran it around for a little and checked the tranny fluid I noticed it was low, not on the dipstick. I didn't have any fluid at time to put in so I have to get some. Could this cause it or do you think its something with the fuel air/mixture screws at the bottom base of carb. There are 2 adjustment screws.
Also, I can't move the 4 wheel drive shifter at all. Seems as if it is frozen. You should be able to just move it anytime right? Nothing special you have to do to put it in 4 wheel drive or out like step on brake or be moving or anything right?
Wizard
Guns, God, and Country. U.S. Veteran
Re: 79 Power Wagon Stalls when put into Gear [Re: Wizard] #1544002
12/05/13 04:07 PM
12/05/13 04:07 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
Shoot some carb cleaner down the air bleeds.
I turn in screws till it stumbles and back out 1.5.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: 79 Power Wagon Stalls when put into Gear [Re: Wizard] #1544003
12/05/13 07:02 PM
12/05/13 07:02 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
1 bad gas 2 low transmission fluid
Re: 79 Power Wagon Stalls when put into Gear [Re: d-150] #1544004
12/05/13 07:06 PM
12/05/13 07:06 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Vacuum leak is also possible.
Make sure the carb is tight to the intake, and check vacuum lines.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 79 Power Wagon Stalls when put into Gear [Re: hp383] #1544005
12/05/13 07:34 PM
12/05/13 07:34 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Gas is fresh and everything is tight and no vacuum leaks. Possibly the accelerator pump someone else mentioned which I did not replace during the carb rebuild due to I could not get it out of the carb no matter how much I tried. Will have to see if it is shooting gas when I move the linkage and look down into it.
Re: 79 Power Wagon Stalls when put into Gear [Re: Wizard] #1544006
12/05/13 08:16 PM
12/05/13 08:16 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Big red flag. Was it squirting fuel before rebuild? And what carb do you have?
Re: 79 Power Wagon Stalls when put into Gear [Re: redraptor] #1544007
12/05/13 08:57 PM
12/05/13 08:57 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I don't know if it was squirting fuel before the rebuild. I have a 2 barrel model 2210 or 2245 have to look at box to make sure. What kind of tool do you use to get accelerator pump out of carb? I could not budge it out with a screwdriver I believe and it started to strip.
Re: 79 Power Wagon Stalls when put into Gear [Re: Wizard] #1544008
12/06/13 07:55 PM
12/06/13 07:55 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
On every carb I've worked on, once you've removed all the linkages and top of the carb, the shaft and plunger pulls right out. Dunno how it could move while running then not pull out when torn down.
Re: 79 Power Wagon Stalls when put into Gear [Re: redraptor] #1544009
12/24/13 05:26 PM
12/24/13 05:26 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Well, I found out what was causing the problem this past weekend. All it was the little metal part I had on backwards that connects to a 3 1/2 long metal connector that hooks to the throttle. The metal piece that I had on backwards pushes down on a plunger that is on top of the carb.
It was not the accerator pump as that squirts fine. So, didn't have to take the carb back off. Got lucky. Thanks to all who shot some ideas out.
Wizard
