Page 7 of 8 1 2 3 4 5 6 7 8
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542799
12/07/13 08:26 PM
12/07/13 08:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok first ill address Monte, finally zeroed in on where you coming from, the head. The head configuration is not what defines a mopar by itself,the distributor,timing chain boss that sticks out from the block,oil pump on external front,and skirted block DEFINES A MOPAR. AS far as heads up racing there is none in the DC. Va. MD. area that i know of, it was tried a couple times and the big guys thew cubic money at it and poof gone. I'm sure we will have to use the twisted head till someone builds a better head down the road.It wasn't so much Alderman i was watching but the wedge head and i knew they where doomed because they where limited on bore size(for big valves)WE both have opinions and that's what makes the world go around, have a good day.
Re: 5" bore space Mopar blocks [Re: moparmafia] #1542800
12/07/13 09:12 PM
12/07/13 09:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
moparmafia, since you mentioned Chevy guys,as a group, if you say i got a race car they want to know what type chevy you got, then look at me real funny when i say mopar, not a clue. Chevy's got your kings and then you got your peasants, like people who join those cult groups, not saying we don't have our fair share but we tend to be more in the thinking group and not eat what's shoved in front of us. More of an educated consumer. Now the "Charger"... a 4-door butt-ugly car, call it a Coronet not the great Charger name,same for the new Dart, you can only take so much blasphemy for the sake of marketing.
Re: 5" bore space Mopar blocks [Re: MR_P_BODY] #1542801
12/07/13 10:32 PM
12/07/13 10:32 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
But you have all the weight and you still didnt increase
the HP/CI ratio
Sure you can, more cylinders means lower weight for each part(piston, valve, etc.) The 3L V12's and V10's always made more power than the V8s in F1. You need less recip and valvetrain weight, so you can pull more RPM. Part of the reason for huge bores and short strokes, reduce piston velocity for better ring seal, not just so you can get huge valves in, but there's that too.
Anyways, you build the parts to fit the rules. With no idea of the rules, no point in spec'ing parts. S/F....Ken M
Re: 5" bore space Mopar blocks [Re: EchoSixMike] #1542802
12/07/13 11:00 PM
12/07/13 11:00 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
this forum needs a b double e double r u n beer run,all u need is a ten and a fiver,car and a key and a sober driver,b double e double r u n,beer run,oh,and some excedrine...............
SFI 25.5 depends,no leak,even at 213 mph....
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542803
12/07/13 11:14 PM
12/07/13 11:14 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Another major issue is that these "die hard" Mopar guys are way too hung up on the Hemi head. A large bore Hemi headed motor is NOT the way to make big N/A power. You need a wedge for that. Hemis make big power when they are boosted or blown, other than that, not so much.
Can you imagine how HEAVY the piston would be in a TRUE Hemi motor with say a 4.750 bore......jeez, you would need the hoist to put pistons in the thing........LOL!!!
Monte
The block can be made for both Hemi and Wedge heads. Wedges for Monte and Hemi's for those that want to be faster.
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542804
12/07/13 11:22 PM
12/07/13 11:22 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I don't know about Summerduck dragstrip. But, there are heads up races in VA just about every weekend. And a friend races several tracks in Maryland in 10.5 outlaw at least once a month.
Leon
Re: 5" bore space Mopar blocks [Re: Leon441] #1542805
12/07/13 11:41 PM
12/07/13 11:41 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Leon
Don't forget Cecil County's monthly Outlaw series
Re: 5" bore space Mopar blocks [Re: Defbob] #1542806
12/08/13 01:28 AM
12/08/13 01:28 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I've talked to Sonny's.....
They told me their HEMI makes more steam than their wedge in these engines. That head is FAR closer to a MOPAR than ANYTHING "chevy". Make that casting look more like the 426 style from the outside and there ya go.
Do a wide pan spacing for windage like the CN billet, with a front mount distributor and you have something that appears way more MOPAR than the next generation "chevy" ( ) HEMI.
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542807
12/08/13 09:37 AM
12/08/13 09:37 AM
Flint, Michigan
E
ex_cuda_guy Offline
ex_cuda_guy  Offline
E
Flint, Michigan
We all want to race a mopar...that's one thing we all agree on. The Ford and Chevy guys are also brand loyal BUT they KNOW the designs are not factory. All they want is the Illusion that it's a Ford a or Chevy. So, if the block and heads are offered by a KNOWN chevy guy.. Like Sonny Lennard then, hell, THAT's a Chevy! The concept is fairly simple. We , or I should say Dan, can do the same thing. It's really all about marketing...(and)..how sick we are of getting beat by brand X'ers. just my
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542808
12/08/13 09:41 AM
12/08/13 09:41 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Naturally any engine combo like that wouldn't be cheap, so I realize that probably eliminates 98% of the people on Moparts.
This being Dans own opinion,I ask why ask for the poll in the first place?This has turned out to be a lesson in futility and is far removed from anyones imput being even considered.If he is planning on entering the market,then we wish him the best of luck.
It did make for interesting conversation and a host of ideas and opinions but in the end the only persons idea he is interested is his own.That the cost eliminates 98% of the people on Moparts speaks volumes about Dans opinion of many here on Moparts which I strongly disagree.
If he would take this to other sites that deal strickly with this type of engine,I think the results would be similar.
Re: 5" bore space Mopar blocks [Re: B G Racing] #1542809
12/08/13 10:55 AM
12/08/13 10:55 AM
Delray beach, Florida
P
Performance Only Offline OP
P
I probably should've chosen my words a little bit better so as to not give the wrong impression, let me explain. 98% of the people on Moparts are bracket racers or street strip guys. I seriously doubt anyone running brackets or street strip cars is going to spring for the kind of coin it would take to buy what I'm proposing. It has nothing to do with the size of their bank account and everything to do with their needs and desires. 98% simply don't need or desire a billet block with 5+ inch bore spacing. That doesn't mean some of those very same people wouldn't have valuable opinions regarding the subject though. In case you didn't notice, there happens to be some pretty smart people that hang out around here. If I didn't want any input or opinions other than my own I wouldn't have posted it here in the first place.
machine shop owner and engine builder
Re: 5" bore space Mopar blocks [Re: B G Racing] #1542810
12/08/13 11:33 AM
12/08/13 11:33 AM
Jerry Kathe Offline
Jerry Kathe  Offline
People simply need to be realistic, if you’re interested in maximum effort power levels you won’t be doing that with oem designs, if oem designs outweigh your desire to achieve maximum effort, so be it. There is a place for all of us.
I would be all about going to the next level with Chrysler compatible parts, don’t really give a damn what they look like, it’s all about $ per HP and longevity. If Chrysler oriented racers are going to see evolution with technology, the gouging has to stop – why the hell would I or anyone else who is somewhat financially savvy want to spend over 40K for 1300 hp on a naturally aspirated bracket piece when you can buy two GM foundations that make the same power for the price of one in Chrysler clothing? I have pride…..I just don’t have ego.
I don’t need a lecture on economic, marketing or business practices – I get it……
However, to turn this market around for Chrysler enthusiasts; a solid, financially stable entity needs to come to the table with “volume of sales” as the objective for profit and not simply “percentage of margin per transaction”…..any loyalist with deep pockets out there want to change history?
I’m sure it would be a bumpy ride on the front half, but the market is there for sustainability…..Indy has already proven that.
I don’t know Dan, or what his thoughts are, but if you’re on our team….don’t discourage him.
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542811
12/08/13 11:36 AM
12/08/13 11:36 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Dan, we can both agree that the statement is misleading and yes I have noticed and some pretty smart guys here on Moparts and respect them and their opinions.Most of them seem to ask "why reinvent the wheel" since what you propose is already available and there is a gage for demand and market which is pretty limited.I also respect you and consider you a friend and as such is only comment out of respect and concern as to why take on such a project.I don't doubt your ability or passion but take the position of a savy businessman and would never take on a project with out having an knowledge of financial reward.I have been approched many times to invest in business ventures and would not consider them with out a solid plan from manufacturing,marketing and profitablity.Just raw materials and residuil waste recovery cost is astronomical let along design and machining cost.As only responding as a respectful friend,I hope you have considered my comments of concern for what their true valve are,and again If this is something your going to persue,I wish you the best.
Respectfully,
Bob
Re: 5" bore space Mopar blocks [Re: B G Racing] #1542812
12/08/13 12:27 PM
12/08/13 12:27 PM
dakotawilly Offline
dakotawilly  Offline
I believe the bottom line is ,if there was no market or money in this,why would cn spend the time effort and money on programing,machinery, and engineering to do a billet hemi block?obviously,its there,if you can build a better mousetrap,it will catch mice........also,they are sold on a order basis so there isn't 100 of these sitting around,pay a deposit,a block is built.good common sense from a business perspective.cn isn't doing these blocks for health reasons,there is a market or it would never be offered in their catalog......................
Re: 5" bore space Mopar blocks [Re: dakotawilly] #1542813
12/08/13 12:47 PM
12/08/13 12:47 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Dan for what class would this engine fit into? To me it seems pretty simple , run a power adder instead of going to the expense of this type of engine if one has to be a Mopar. The fast guys I see on here and other sites use adders.
Re: 5" bore space Mopar blocks [Re: dakotawilly] #1542814
12/08/13 12:57 PM
12/08/13 12:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There is a market,however it's a limited market.To go head to head with those who are producing these now would be a catch up and those who buys these are looking to a proven piece,then lets not forget all the other parts and support unless this will be something that uses what's already available which is also limited.A CNC center to machine blocks is a very expensive item on it's own.I gave my thoughts and opinion enough and won't belabor this subject anymore.I will await and see what and when Dan does with this and if he comes up with a new mousetrap and is sucessful,I will definately take an interest.Again I wish him the best.
Re: 5" bore space Mopar blocks [Re: B G Racing] #1542815
12/08/13 02:12 PM
12/08/13 02:12 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I'm a Bracket Racer and own 2 of the Big Brand XXX engines,and would gladly sell them to buy a Big 5.0 Mopar engine.And I could care less if it looks like a slant 6 or Hemi as long as its a Mopar.
Some say Bracket Racers have no use or do not need such Big engines,well try and Qualify for a T/D or T/S field.
I'm a Racer and I don't know about anyone else but I don't want to have the Slowest race-car at the track.
If there is no need for such a Big engine,why do so many Racers have them?The reason there are no Mopar racers with them is there are none for us to have.Have I not made my point here,some of us not only want them but would buy and run them,and if us Mopar racers can not get them soon there will be no more Mopar racers.There comes a time when you have to do what you must if you want to race.
This is not the right/best word to use but the only one I can think of.Are the ones of you that are against this "Jealous" because if they were made the Mopar stuff you have would be out-dated...or you just do not want anyone to have anything better than what you have or can afford to own one?I just don't understand your reason's if its not for you,you would not have buy one.
Mopar has been stuck in the age for to long.
Had you not rather have this bring you a new 5.0 Mopar engine for Christmas?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542816
12/08/13 02:27 PM
12/08/13 02:27 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Sorry, I am confused I guess. What got this discussion going was YOU saying the "first time I ever saw the Predator head, I said that's a BBC head" but NOW you say the head doesn't matter, it is the block that more or less defines the motor.
Me personally, all I want it some parts that make power. I don't give a damn what they look like. Call it a damn Rambler for all I care.
Monte
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542817
12/08/13 02:28 PM
12/08/13 02:28 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Monte
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542818
12/08/13 08:38 PM
12/08/13 08:38 PM
Flint, Michigan
E
ex_cuda_guy Offline
ex_cuda_guy  Offline
E
Flint, Michigan
Monte
Hey that's an idea, Monte, a 5.3 bore space AMC Brewer head!!
