Page 6 of 8 1 2 3 4 5 6 7 8
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542779
12/06/13 07:33 PM
12/06/13 07:33 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Well said Monte
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542780
12/06/13 08:13 PM
12/06/13 08:13 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
And there you go.......Too much of THIS attitude among Mopar guys, is the reason we don't have cutting edge parts. You are going to have to explain to me how a Predator is a BB Chevy head. Last time I checked, they bolted on a 4.800 bore space Mopar block and NOTHING else, plus they are a spread port head. Show me ONE BB Chevy that EVER came from the factory with a spread port head.
Monte
This attitude is called passion for a certain manufactor, if you don't just hate it when a
GM car wins, your not a true blood Mopar man. If a Mopar with a mopar enginie is not in the final I go home and when a Mopar wins what a felling,now that's attitude!
You get cutting edge parts through innovation, not sticking your nose up the GM guys butt doing what he's already done, you'll always be one step behind eating crumbs.
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542781
12/06/13 08:24 PM
12/06/13 08:24 PM
Delray beach, Florida
P
Performance Only Offline OP
P
Monte
So you're saying it needs to be a factory block and factory heads, since nothing made in the aftermarket is actually mopar. It might bolt up but mopar didn't make it. Obviously you don't cheer on the top fulel or pro stock mopar teams either, since they aren't mopar parts either.
How far do you take it?
machine shop owner and engine builder
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542782
12/06/13 08:54 PM
12/06/13 08:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I do agree with Monty and do believe this is why MOPARS are at the bottom of the food chain.
It doesn't bother me which way you choose to take your beliefs. But I do have one question.
Where would the G3 hemi be placed in? Is it a Mopar or LS engine?
Pull the heads and its very similar to the Ls.
Matt.
Re: 5" bore space Mopar blocks [Re: Performance Only] #1542783
12/06/13 09:06 PM
12/06/13 09:06 PM
fredericksburg,va
fredericksburg,va
Some how my point is not getting through. There are very very few parts made by "Mopar" on the engine now. A top fuel engine still resembles a Mopar Hemi, looks like it feels like it but not made by Mopar. There are certain things that define a Mopar,just like Chevys and Fords have theirs. It does't look like a chevy or ford does it? Real Mona Lisa fake Mona Lisa still look the same. Heck just make a square box to put it in with the headers sticking out then put it in a square car like NASCAR does and put a decal saying whos manufacture it is today and root for smiling Johnny B. Quick. Make somthing that stands out from the crowd not just blend in. Mopar guys have money they are just smarter with it.
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542784
12/06/13 10:12 PM
12/06/13 10:12 PM
How about one with dual overhead cams and get rid of the pushrods.
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542785
12/06/13 10:33 PM
12/06/13 10:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You never answered my question about how a Predator head is like a BBC head, since NO BBC EVER came with a head like that.
And did you root for the Mopar Pro Stocks when they ran the "Eicke" head.
If all Mopar guys had you attitude about building something new and innovative, we would be getting our butts kicked worse than we are. Bottom line, there is NO head that LOOKS like a Mopar head than can remotely compete with the other brands on a heads up level. So I guess that's the way you like it huh........And DON"T say what about Top Fuel. That engine has as much in common with a factory Hemi as my lawn mower engine, which has the spark plug in the middle of the head.
Monte
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542786
12/06/13 10:55 PM
12/06/13 10:55 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
A good starting point would be to make a cast water version of AJPE 5.3 Hemi. A lot of designing has already been done, rocker gear, head bolt pattern, intakes, gaskets/o-rings, valve covers, etc.
Re: 5" bore space Mopar blocks [Re: Defbob] #1542787
12/06/13 11:02 PM
12/06/13 11:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Another major issue is that these "die hard" Mopar guys are way too hung up on the Hemi head. A large bore Hemi headed motor is NOT the way to make big N/A power. You need a wedge for that. Hemis make big power when they are boosted or blown, other than that, not so much.
Can you imagine how HEAVY the piston would be in a TRUE Hemi motor with say a 4.750 bore......jeez, you would need the hoist to put pistons in the thing........LOL!!!
Monte
Re: 5" bore space Mopar blocks [Re: Defbob] #1542788
12/06/13 11:05 PM
12/06/13 11:05 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
for drag weekers I could use a head that flows over 620
Re: 5" bore space Mopar blocks [Re: Defbob] #1542789
12/06/13 11:06 PM
12/06/13 11:06 PM
P
P
What would be the point in doing that? Please explain.
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542790
12/07/13 12:22 AM
12/07/13 12:22 AM
fredericksburg,va
fredericksburg,va
Monte
fist time i saw the predator head i said to myself they put a chevy-oldsmobile "design" (not sure you understand the difference) head on a mopar. haven't watched prostock since Alderman. and if you say the top fuel engine doesn't look like a 426 hemi i might as well be talking to a 5 year old, oh and where do we run the competition heads up other than prostock and don't say the stutter box classes. and with enough attitudes we wouldn't have to put up with the junk made today,they can't make a cast block that's worth a darn, with all the technology today we can't even equal the 1950s casting process. the age of greatness is dead and gone
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542791
12/07/13 12:55 AM
12/07/13 12:55 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
that's what I think also,come on! they have been casting blocks since the beginning of time.every time something new springs up,its overwhelmed with problems and goes belly up.you don't see problems like that with model t's and a's,they were cast by cavemen and are still around.the technology is there to do it right,but those who do it are obviously escapees from bellview,or,just not getting the right people.the factories do it everyday,why cant others???? my guess is if its cast right the first time,instead of 357 changes and upgrades it wouldn't cost 4grand for a block,and another 4 grand to get it machined just to work......nuff said.....
SFI 25.5 depends,no leak,even at 213 mph....
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542792
12/07/13 02:02 AM
12/07/13 02:02 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Cudaman, I'm a diehard like you but your argument lacks weight in the area of resolve. Your argument doesn't solve the design flaws in current Mopar configurations. Its doesn't aid in finding options for Mopar racers that want to advance past 40year old technology. As a person working on designing a new cylinder head, there are many flaws in the wedge design that you simply cannot use when you want to make over 2.5HP/ci. Improving and building upon these flaws is how we advance and sometimes the flaws are such that its more beneficial to start with a clean sheet. I for one go so upset of over not having any options I took upon myself to do my own canted head design and start the legwork for it. That design looks nothing like a Mopar head due to current OEM constraints, you can achieve much more by moving the configuration around and that is the innovation of design. Finding ways to better what was done in the past and having the guts to purpose design something brand new for the mopar faithful. You don't have to walk in the footsteps of the past to advance a design, your learn from what was done and use that to create something new purpose built for use with a mopar product.
I give much props to anyone willing to think outside the box and progress mopar technology. I sure plan to as I'm given the opportunity.
Adriel Paradise
Substation Design Engineer III
Re: 5" bore space Mopar blocks [Re: Adrielp] #1542793
12/07/13 02:40 AM
12/07/13 02:40 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Hmm, if you're looking for higher specific output per cube, and you're fabricating something completely new, I get away from the V-8 configuration all together. Cut the back two cylinders off one block, and the front two off another, make a V-12. An easy 850+ inches and a fewer issues with valve train.
Or something OHC like a McGee. S/F....Ken M
Re: 5" bore space Mopar blocks [Re: EchoSixMike] #1542794
12/07/13 11:32 AM
12/07/13 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
But you have all the weight and you still didnt increase
the HP/CI ratio
Re: 5" bore space Mopar blocks [Re: cudaman1969] #1542795
12/07/13 02:26 PM
12/07/13 02:26 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Some how my point is not getting through. There are very very few parts made by "Mopar" on the engine now. A top fuel engine still resembles a Mopar Hemi, looks like it feels like it but not made by Mopar. There are certain things that define a Mopar,just like Chevys and Fords have theirs. It doesn't look like a chevy or ford does it? Real Mona Lisa fake Mona Lisa still look the same. Heck just make a square box to put it in with the headers sticking out then put it in a square car like NASCAR does and put a decal saying whos manufacture it is today and root for smiling Johnny B. Quick. Make somthing that stands out from the crowd not just blend in. Mopar guys have money they are just smarter with it.
Monte
I don't understand the difference...yeah right...LOL!! Where do we run heads up.........oh, I don't know, how about Pro-Mod and any number of other heads up classes all over the country. Pro-Stock and that technology doesn't mean squat to you and me. Because even if we could afford one, try taking it to your local track and enter a "heads-up" class and you will be on the trailer first round. And while we are on that subject, care to tell me what factory Mopar head our current Pro-Stock head closely resembles. The answer, NONE.
You like Alderman, ok, lets look at that. They started with the B-1, then the PSO, then the TS. So had that development line kept going, do you think the next heads would have LOOKED like a Chrysler head, hell no. It would have been another aftermarket race head, just like is on every other motor out there. Warren Johnson more or less designed the head that became known as the DRCE and virtually EVERY wedge head, for virtually EVERY make, now follows that basic principle. Our own Pro-Stock Hemi is nothing more than a "twisted" wedge chamber with the plug through the middle of it. It is not even CLOSE to a Hemi, but Mopar chose some slick marketing to get the fans to jump on board by calling it such and getting all the "die hards" to accept it.
Monte
Re: 5" bore space Mopar blocks [Re: Monte_Smith] #1542796
12/07/13 06:38 PM
12/07/13 06:38 PM
Ky
moparmafia Offline
moparmafia  Offline
Ky
The way i see it is the mopar crowd that is the problem. every time a new product comes out or is even thought of it has to go through the usual bullcrap from the mopar masses. I have ford and chevy friends and never not ONE time have i heard them complain that their new product looks like the last one, all they care about is function of the product. most of the parts on their cars were produced by an aftermarket company and they do not complain. i am surprised a mopar supplier can accomplish anything with all the bs. how does mopar even come out with a newly designed car since it looks nothing like what is already out there on the street. heck it cant be a mopar if it looks totally different. all i heard when the new charger came out is how ugly they are and they shouldnt be called a mopar. i heard it all weekend at the mopar nats that first year they were out. i got so sick of hearing it and i actually like them 4 doors and all. even though now they are accepted by most they had to go through the same bs. i say if you can afford to make anything mopar better or faster than by all means go ahead and do not listen to the whiny mopar stiffs who cannot accept change and just leave them be. I am die hard mopar but i am willing to accept change because its the only way to improve.
Re: 5" bore space Mopar blocks [Re: moparmafia] #1542797
12/07/13 06:48 PM
12/07/13 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
1000%.... a LOT of these guys are still living
in the 60s.. I'll take anything that will help go fast...
hell I have chevy rods in all my stuff... granted
when the Ram truck first came out I didnt care for
it but look at it now... truck of the year 2 times
in a row
Re: 5" bore space Mopar blocks [Re: moparmafia] #1542798
12/07/13 07:03 PM
12/07/13 07:03 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Anything that is "Mopar" that furthers the Mopar banner is fine by me.
True, the 5 and 5.3 Chevys and Fords are pretty far removed from the stock stuff, BUT, they're evolutions of them so that's why they call them Chevys and Fords and fair enough. Mopar guys should have the same right to call it "ours" as well.
The purist in me would want it to somewhat resemble a Mopar in some aspect, but it's not the main issue by along shot. If it used a BB water pump and a Y block confit, that would more than satisfy the "purist" in me. A head configured something like a SB2.2 would kind of look like a BB and be able to use a canted/HEMI valve arrangement.
Also, if it was a cast block I imagine it could be sold cheaper and you probably would get more of them out the door. Would cast be strong enough for the 1800 HP range? That 5300 AJPE HEMI looks pretty slick, a cast block and wedge head would be sweet.
If I could afford one I would definitely go with a 5/5.3 Mopar
