hearders are ready to be tiged and coated #1541727
11/30/13 01:40 AM
11/30/13 01:40 AM
nc
E
earthmover Offline OP
E
nc
got the headers all done..had them done before but wanted a little more tire clearance so took them apart and redid them.. great learning but time is a must ..
Re: hearders are ready to be tiged and coated [Re: earthmover] #1541728
11/30/13 09:46 AM
11/30/13 09:46 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Did you use a header kit?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: hearders are ready to be tiged and coated [Re: earthmover] #1541729
11/30/13 09:51 AM
11/30/13 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They look good... do they point downward on the collector..
how much ground clearance
Re: hearders are ready to be tiged and coated [Re: MR_P_BODY] #1541730
11/30/13 10:33 AM
11/30/13 10:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think I would have took them out the fenders for more ground clearance. Mike did you replace the support bar you had to move? I would do that if you didn't.
Re: hearders are ready to be tiged and coated [Re: DusterDave] #1541731
11/30/13 11:20 AM
11/30/13 11:20 AM
nc
E
E
nc
yes its a stalh kit but I hear they are going under so sad..
Re: hearders are ready to be tiged and coated [Re: MR_P_BODY] #1541732
11/30/13 11:23 AM
11/30/13 11:23 AM
nc
E
E
nc
hey mrp yes they point down just a little at the collector with the bar that runs from the chassis to the body it was my only way to get them to work the way I have them...I have about 1/2 clearance from the frame and other stuff.. I plan to make a plate that goes under the master and brake pedal to help block what heat will be there..
Re: hearders are ready to be tiged and coated [Re: Quicktree] #1541733
11/30/13 11:27 AM
11/30/13 11:27 AM
nc
E
E
nc
hey tony a bunch of my buddies tried to get me to go out the fenders ....maybe down the road once I get the new motor done for it.. I plan to put the bars back once I have everything in order and doing 1 last check on stuff...but they will be back in there...
not on a lot lately did you get your gasket stuff worked out?????
Re: hearders are ready to be tiged and coated [Re: earthmover] #1541734
11/30/13 11:51 AM
11/30/13 11:51 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yes the heads were ported to much getting into head stud area which are under oil pressure. hope to have it back together soon.
Re: hearders are ready to be tiged and coated [Re: Quicktree] #1541735
11/30/13 11:28 PM
11/30/13 11:28 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
Headers look great. I like the ram head cut into the motor plate. Looks awesome.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: hearders are ready to be tiged and coated [Re: nasty68] #1541736
11/30/13 11:49 PM
11/30/13 11:49 PM
nc
E
E
nc
lol thanks quicktree tony is the man
Re: hearders are ready to be tiged and coated [Re: earthmover] #1541737
12/01/13 12:45 AM
12/01/13 12:45 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's a good looking set of headers. If you need a coater Rick is good. He did mine. He put 2000* black on the inside and the 1300* ceramic on the outside. They were blue when he got em lol.
Ricks custom coating
502 648-8438
