hearders are ready to be tiged and coated
#1541727
11/30/13 01:40 AM
11/30/13 01:40 AM
Posts: 2,449 nc
earthmover
nc
Re: hearders are ready to be tiged and coated
[Re: earthmover]
#1541728
11/30/13 09:46 AM
11/30/13 09:46 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Did you use a header kit?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1541731
11/30/13 11:20 AM
11/30/13 11:20 AM
Posts: 2,449 nc
earthmover
nc
yes its a stalh kit but I hear they are going under so sad..
[Re: MR_P_BODY]
#1541732
11/30/13 11:23 AM
11/30/13 11:23 AM
Posts: 2,449 nc
earthmover
nc
They look good... do they point downward on the collector.. how much ground clearance
hey mrp yes they point down just a little at the collector with the bar that runs from the chassis to the body it was my only way to get them to work the way I have them...I have about 1/2 clearance from the frame and other stuff.. I plan to make a plate that goes under the master and brake pedal to help block what heat will be there..
[Re: Quicktree]
#1541733
11/30/13 11:27 AM
11/30/13 11:27 AM
Posts: 2,449 nc
earthmover
nc
I think I would have took them out the fenders for more ground clearance. Mike did you replace the support bar you had to move? I would do that if you didn't.
hey tony a bunch of my buddies tried to get me to go out the fenders ....maybe down the road once I get the new motor done for it.. I plan to put the bars back once I have everything in order and doing 1 last check on stuff...but they will be back in there...
not on a lot lately did you get your gasket stuff worked out?????
[Re: earthmover]
#1541734
11/30/13 11:51 AM
11/30/13 11:51 AM
Quicktree
yes the heads were ported to much getting into head stud area which are under oil pressure. hope to have it back together soon.
