cal trac ? #1541383
11/29/13 12:25 AM
11/29/13 12:25 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
i'm thinking of putting cal tracs on the bracket car and i'm wondering how you determine the ride heighth you want. i'm now using super stock springs 002& 003 and the car sits slightly raked. all info is appreciated. dave
Re: cal trac ? [Re: 3ddart] #1541384
11/29/13 12:48 AM
11/29/13 12:48 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You can order the split mono's at stock height or lower.Where do you want the rear to be??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: cal trac ? [Re: hemi-itis] #1541385
11/29/13 12:57 AM
11/29/13 12:57 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
About where it is now. Car handles well and I don't want that to change. 60s are not as consistent as I would like. It was real consistent but I put a different set of ss springs on it following a friends advice and now it seems to have lost the consistency.
Re: cal trac ? [Re: 3ddart] #1541386
11/29/13 01:13 AM
11/29/13 01:13 AM
hemi-itis Offline
hemi-itis  Offline
I have 2 front spring eye holes so I can lower the rear.IMHO go for the inch lower than stock.
Re: cal trac ? [Re: 3ddart] #1541387
11/29/13 01:22 AM
11/29/13 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you lower the back some it should help your 60'
and be more consistent(easier to get the front weight
to transfer to the rear)... by rights it should only
change the caster a SMALL amount(for the better)..
it will add a small amount of caster but very little
with the angle change
Re: cal trac ? [Re: 3ddart] #1541388
11/29/13 10:56 AM
11/29/13 10:56 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Caltracs offer split mono's up to 2 inch over stock ride height. Looking at your car you would need at least +1 inch to sit like it is sitting now.
I originally went with +2 inch on my ebody and it sat higher than I liked so I went back to +1 inch and now it looks and works perfect.
Re: cal trac ? [Re: 3ddart] #1541389
11/29/13 11:20 AM
11/29/13 11:20 AM
Why not look into a decent ladder bar set up with coil overs now Skip the intermediate steps to traction and go straight to the better set up now The only way I would run CalTracs now is if the car I raced had rules that made them the only other option than SS springs
Re: cal trac ? [Re: Cab_Burge] #1541390
11/29/13 11:44 AM
11/29/13 11:44 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
cab: it's all a $s thing. i'm 62 and have had a couple of back surgerys and i'm a 1 man band at the track so it just keeps getting harder to do. this has been a great car for me (3 championships over 12 yrs) but valiants aren't the most popular car out there so i won't recoup many of the $s i throw at it. if i go bars i would want to go away from the 8 3/4 thats under it now so it becomes a spiraling $ vacume. i ran epso ss springs for yrs with very good consistency but moved those springs to my ss clone car, and replaced them with a mopar set and the consistency just isn't there now. i already have the rancho shocks so cal tracs seem to be a logical move to me. this is a low 11/ high 10 1/4 mile car and i'm ok with that. i never really got caught up in the being the fastest car at the track deal, if figure you need a top fuel car to do that lol
Re: cal trac ? [Re: 3ddart] #1541391
11/29/13 12:36 PM
11/29/13 12:36 PM
I use to live close to where the Cal trac set up was developed in SO CA, I ran a NHRA stocker when John Calvert was racing in stock and him and the Dreyer famiy where developing that system. If cost was the only issue the ladder bars used with a floater or slider setup on leaf springs is almost the same $ as the Caltracs with thier springs and shocks I know of some racers, bracket racers as well as NHRA Stock racers and some heads up no breakout racers in PSCA that really had to fight and work hard to get the results they wanted from CalTracs, some didn't get them to work, hence the two piece leaf springs and so on I don't know of any racers that put in a ladder bar set up close to proper on the installation that didn't work good to start with There are several racers on here who have used both, none of them siad that thier Caltracs where better than the ladder bars they replaced them with later I have driven many different leaf spring cars, stocker and bracket cars, same thing on ladder bar cars, the ladder bar cars are easier to drive and much more consistent I have not owned, driven or use the Caltracs so I don't have any expereinces with them other than what friends of mine who have used them have done and said Us old timers need to help others when we can IHTHs
Re: cal trac ? [Re: Cab_Burge] #1541392
11/29/13 12:46 PM
11/29/13 12:46 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
And I appreciate that help!!!!!! That's why I asked.
Re: cal trac ? [Re: 3ddart] #1541393
11/29/13 01:45 PM
11/29/13 01:45 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
Dave when I put mine on several years ago it took a while to get them dialed in I didn't get there springs I removed one leaf from each side this was a recommendation from the tech person.
Re: cal trac ? [Re: 3ddart] #1541394
11/29/13 03:21 PM
11/29/13 03:21 PM
Mohnton, Pa
Mohnton, Pa
You will be very happy with Caltracs. I wasted years trying to get MT ET Street Radials to hook with SS springs. I finally bought Caltracs this spring.
The 60 fts were instantly consistant unless I hooked the car to hard then it would unload the tire. I finally listened to the people that said you need a double adjustable rear shock to hook drag radials. I put them on in time for the last race of the year. The car ran quicker and faster. I have a very nose heavy heavy car with a small tire drag radial street tire and the Caltracs worked. Your car should be a lot easier to set up than mine. For the money I don't think you can do any better than Caltracs.
Re: cal trac ? [Re: 3ddart] #1541395
11/29/13 04:13 PM
11/29/13 04:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d call em for sure and talk to em about your needs but agree on a double adj. shock in the rear especially if you`re running in the 9`s cos the old 5-way Ranchos don`t work for me anymore. I use lowering blocks and asside from what some may say, even Calvert and others goin real fast use em. While you`re at it ask em about the 25" ft. segment deal.............
Re: cal trac ? [Re: Thumperdart] #1541396
11/29/13 06:39 PM
11/29/13 06:39 PM
hemi-itis Offline
hemi-itis  Offline
Caltrac's here Shock adjustability seems to be the answer for the front & rear. The choices and prices have a huge spread
Re: cal trac ? [Re: hemi-itis] #1541397
11/29/13 07:52 PM
11/29/13 07:52 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
I have put Cal tracs on a couple cars with little improvent....... Got way more out of good shocks..... even more out of setting the front up with 5 inches of travel and making the front loose........
Re: cal trac ? [Re: 3ddart] #1541398
11/29/13 10:04 PM
11/29/13 10:04 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dave you will love the Caltracs. Your car runs about what my brothers Cuda does and his 60 fts are crazy consistent even at Mag. I would sug that you call Caltrac and talk to them about your set up. I did that for the Belvedere I'm building and they were very helpful.
Ok
Re: cal trac ? [Re: SSDart] #1541399
11/29/13 10:13 PM
11/29/13 10:13 PM
Mohnton, Pa
Mohnton, Pa
On my car the first day I ran the Caltracs I noticed two three things. The sixty foot times were consistant to within thousanths unless I made an adjustment Everytime I made an adjustment the car went faster.
My reaction times were a lot quicker and for the first time they were consistant.
I wasted a lot of time messing with SS springs and there are guys that say they work for them but for me there was no comparison between SS springs and Caltracs.
Re: cal trac ? [Re: DodgeCharger] #1541400
11/29/13 10:37 PM
11/29/13 10:37 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
a lot of guy's us the 25 in. front's .
I still have the 20in. on mine with 55.5% weight on the front of my car.
my car hang's the wheel's out to around the 100ft. mark.
Re: cal trac ? [Re: SSDart] #1541401
12/04/13 12:24 AM
12/04/13 12:24 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
This right here is what it will take for an A-body to work awesome with caltracs. Beep
