Re: cal trac ?
[Re: 3ddart]
#1541386
11/29/13 01:13 AM
11/29/13 01:13 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have 2 front spring eye holes so I can lower the rear.IMHO go for the inch lower than stock.
Re: cal trac ?
[Re: 3ddart]
#1541387
11/29/13 01:22 AM
11/29/13 01:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
About where it is now. Car handles well and I don't want that to change. 60s are not as consistent as I would like. It was real consistent but I put a different set of ss springs on it following a friends advice and now it seems to have lost the consistency.
If you lower the back some it should help your 60' and be more consistent(easier to get the front weight to transfer to the rear)... by rights it should only change the caster a SMALL amount(for the better).. it will add a small amount of caster but very little with the angle change ![](/ubbthreads/images/graemlins/wave.gif)
Re: cal trac ?
[Re: 3ddart]
#1541391
11/29/13 12:36 PM
11/29/13 12:36 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I use to live close to where the Cal trac set up was developed in SO CA, I ran a NHRA stocker when John Calvert was racing in stock and him and the Dreyer famiy where developing that system. If cost was the only issue the ladder bars used with a floater or slider setup on leaf springs is almost the same $ as the Caltracs with thier springs and shocks ![](/ubbthreads/images/graemlins/scope.gif) I know of some racers, bracket racers as well as NHRA Stock racers and some heads up no breakout racers in PSCA that really had to fight and work hard to get the results they wanted from CalTracs, some didn't get them to work, hence the two piece leaf springs and so on ![](/ubbthreads/images/graemlins/shruggy.gif) I don't know of any racers that put in a ladder bar set up close to proper on the installation that didn't work good to start with ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) There are several racers on here who have used both, none of them siad that thier Caltracs where better than the ladder bars they replaced them with later ![](/ubbthreads/images/graemlins/shruggy.gif) I have driven many different leaf spring cars, stocker and bracket cars, same thing on ladder bar cars, the ladder bar cars are easier to drive and much more consistent ![](/ubbthreads/images/graemlins/thumbs.gif) I have not owned, driven or use the Caltracs so I don't have any expereinces with them other than what friends of mine who have used them have done and said ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Us old timers need to help others when we can ![](/ubbthreads/images/graemlins/bow.gif) IHTHs ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: cal trac ?
[Re: 3ddart]
#1541398
11/29/13 10:04 PM
11/29/13 10:04 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
Dave you will love the Caltracs. Your car runs about what my brothers Cuda does and his 60 fts are crazy consistent even at Mag. I would sug that you call Caltrac and talk to them about your set up. I did that for the Belvedere I'm building and they were very helpful.
Ok
Re: cal trac ?
[Re: SSDart]
#1541401
12/04/13 12:24 AM
12/04/13 12:24 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
I have put Cal tracs on a couple cars with little improvent....... Got way more out of good shocks..... even more out of setting the front up with 5 inches of travel and making the front loose........
This right here is what it will take for an A-body to work awesome with caltracs. Beep ![](/ubbthreads/images/graemlins/Twocents.gif)
