Who sells a drop base for my 340 air cleaner? #154063
11/20/08 12:35 PM
11/20/08 12:35 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I am about to put a performer RPM intake on the 69 'Cuda, and I could use a little extra clearance. Anyone know where I can buy one?
Re: Who sells a drop base for my 340 air cleaner? [Re: OA5599] #154064
11/20/08 12:39 PM
11/20/08 12:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
buy one WHAT ? not enough info .
there are plenty of drop base air cleaners , a little more specific please .
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154065
11/20/08 12:42 PM
11/20/08 12:42 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Oops. Sorry. I want to find a drop base for my factory 69 Cuda 340 air cleaner.
Re: Who sells a drop base for my 340 air cleaner? [Re: OA5599] #154066
11/20/08 12:45 PM
11/20/08 12:45 PM
JohnRR Offline
JohnRR  Offline
The only drop base that will fit it is the base from a Ford Motorsport aircleaner , BUT the STOCK fuel line hits it . On a 340 with an RPM I wouldn't think you'd need a drop base
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154067
11/20/08 05:30 PM
11/20/08 05:30 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I ran that air cleaner on my 69 Cuda with a LD340 and a 1" spacer.
Re: Who sells a drop base for my 340 air cleaner? [Re: AdamR] #154068
11/21/08 10:43 AM
11/21/08 10:43 AM
JohnRR Offline
JohnRR  Offline
Adam , what air cleaner , the stock unsilenced or the dropped ford unit ?
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154069
11/21/08 11:38 AM
11/21/08 11:38 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I have one on my 72 RR. It came on my Dart when I bought it. Think the guy got it from MP.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Who sells a drop base for my 340 air cleaner? [Re: 70dart360] #154070
11/21/08 12:56 PM
11/21/08 12:56 PM
JohnRR Offline
JohnRR  Offline
picture ???
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154071
11/21/08 02:19 PM
11/21/08 02:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Edelbrock makes a banjo fitting for eddy and carter carbs. Really helps if you have a fuel inlet/air cleaner issue. I have one sitting in my tool box that I ran for years.
Re: Who sells a drop base for my 340 air cleaner? [Re: Neil] #154072
11/21/08 02:23 PM
11/21/08 02:23 PM
JohnRR Offline
JohnRR  Offline
I bought one , never used it , should I need to run the ford motorsport drop base I'll bend up a new line to it .
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154073
11/21/08 03:50 PM
11/21/08 03:50 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I just bought a cheap 14" drop base air cleaner and traced the stock 13" base on the bottom of the drop base air cleaner and cut along the line smoothed out the edges and voila!!!! Drop base for my unsilenced air cleaner. Pretty easy and cheap to do.
In pic: Victor 340 intake, 1" spacer, 950 quickfuel carb, unsilenced air cleaner (custom drop base) - fits under stock hood - priceless..
I think Summit sells just the drop bases.
Re: Who sells a drop base for my 340 air cleaner? [Re: OA5599] #154074
11/21/08 09:55 PM
11/21/08 09:55 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
put an LD 340 intake on it it'll run much better and probably be faster! my almost stock 340 thru manifolds went high 12,s@ 109 mph with one... oh and street tires [f 70-14] and thru full exhaust and the stock [as born with] converter ... dan
Re: Who sells a drop base for my 340 air cleaner? [Re: Cuda340] #154075
11/21/08 11:21 PM
11/21/08 11:21 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
After trimming the 14" drop base there was still enough "ledge" for the air filter element to sit on ?
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154076
11/22/08 09:09 AM
11/22/08 09:09 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Stock un silenced.
Re: Who sells a drop base for my 340 air cleaner? [Re: OA5599] #154077
11/22/08 03:41 PM
11/22/08 03:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
be careful not to lower the lid of the air cleaner too far or it can disrupt the air flow into the carb at higher RPM
Re: Who sells a drop base for my 340 air cleaner? [Re: TJP] #154078
11/22/08 08:18 PM
11/22/08 08:18 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Ford motorsports makes an air cleaner that has a drop base and is 13" like your stock 340 air cleaner. I found one used on ebay and it worked perfect. still using it on my 68 charger/440/rpm intake.
here's one. it's expensive, but keep your eyes open. I got mine for 25 bucks. they come up used from time to time.
http://cgi.ebay.com/ebaymotors/FORD-MUST...sQ5fAccessories
Re: Who sells a drop base for my 340 air cleaner? [Re: Pool Fixer] #154079
11/22/08 09:04 PM
11/22/08 09:04 PM
JohnRR Offline
JohnRR  Offline
what carb are you using , the drop base fits a holley , you need to get creative with a carter , I think the linkage is also a potnetial interferance also ? I have the base , just haven't gotten around to using it yet , also K+N has a taller filter that fits it , it's about 1/2 " more element height
Re: Who sells a drop base for my 340 air cleaner? [Re: JohnRR] #154080
11/22/08 09:25 PM
11/22/08 09:25 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I'm running a demon
