Re: Who sells a drop base for my 340 air cleaner?
[Re: OA5599]
#154064
11/20/08 12:39 PM
11/20/08 12:39 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I am about to put a performer RPM intake on the 69 'Cuda, and I could use a little extra clearance. Anyone know where I can buy one?
buy one WHAT ? not enough info .
there are plenty of drop base air cleaners , a little more specific please .
[Re: AdamR]
#154068
11/21/08 10:43 AM
11/21/08 10:43 AM
JohnRR
U.S.S.A.
I ran that air cleaner on my 69 Cuda with a LD340 and a 1" spacer.
Adam , what air cleaner , the stock unsilenced or the dropped ford unit ?
[Re: JohnRR]
#154069
11/21/08 11:38 AM
11/21/08 11:38 AM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
I have one on my 72 RR. It came on my Dart when I bought it. Think the guy got it from MP.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#154070
11/21/08 12:56 PM
11/21/08 12:56 PM
JohnRR
U.S.S.A.
picture ???
[Re: Neil]
#154072
11/21/08 02:23 PM
11/21/08 02:23 PM
JohnRR
U.S.S.A.
Edelbrock makes a banjo fitting for eddy and carter carbs. Really helps if you have a fuel inlet/air cleaner issue. I have one sitting in my tool box that I ran for years.
I bought one , never used it , should I need to run the ford motorsport drop base I'll bend up a new line to it .
[Re: JohnRR]
#154076
11/22/08 09:09 AM
11/22/08 09:09 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Stock un silenced.
[Re: TJP]
#154078
11/22/08 08:18 PM
11/22/08 08:18 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Ford motorsports makes an air cleaner that has a drop base and is 13" like your stock 340 air cleaner. I found one used on ebay and it worked perfect. still using it on my 68 charger/440/rpm intake. here's one. it's expensive, but keep your eyes open. I got mine for 25 bucks. they come up used from time to time. http://cgi.ebay.com/ebaymotors/FORD-MUST...sQ5fAccessories
[Re: Pool Fixer]
#154079
11/22/08 09:04 PM
11/22/08 09:04 PM
JohnRR
U.S.S.A.
what carb are you using , the drop base fits a holley , you need to get creative with a carter , I think the linkage is also a potnetial interferance also ? I have the base , just haven't gotten around to using it yet , also K+N has a taller filter that fits it , it's about 1/2 " more element height
[Re: JohnRR]
#154080
11/22/08 09:25 PM
11/22/08 09:25 PM
Pool Fixer
Coram, NY
I'm running a demon
