Professional Products Dampers. Any good?
#1539756
11/25/13 03:56 PM
11/25/13 03:56 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Or who else makes a damper like this.
Similar to stock appearance in front. LA360 external balance Counterweights that bolt to rear of damper. Not chromed. SFI not needed.
Closest I can find is the Professional Products brand Powerforce Series steel unit, and the ProRace Performance Products brand Pro Street nodular iron.
The Pro-Race is the less expensive of the two, which may or may not be a good thing.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Professional Products Dampers. Any good?
[Re: 1Fast340]
#1539760
11/25/13 05:13 PM
11/25/13 05:13 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run a powerforce damper on my 451. Been there for a few years, thousands of street miles, and many trips to 6500. No issues to speak of. I had the motor apart last winter, and the damper looked good as new. Personally, I believe that most issues people have with many products that arent "top dollar", are actually installation / build errors that get blamed on the part. If its a high dollar part that lets go, its "Wow - Bummer. Good luck figuring out what happened". If its a less than high dollar part, its "thats what you get for buying cheap parts".
[Re: StealthWedge67]
#1539761
11/25/13 05:32 PM
11/25/13 05:32 PM
The Pro Race and Pro Street are good units Professional Products not so much--they have soft rubber. I have used a ton of the Pro units on many brands with excellent results. Pioneer stock replacement is OEM or better quality--very stock looks-- but not cheap
[Re: Performance Only]
#1539766
11/25/13 08:24 PM
11/25/13 08:24 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
I use the Pro Street balancer on 2 different engines including the eng in my 63 right now. I have not had any problems with them and I do race my car sometimes. Ron
The pioneer brand is made by pro-bond and is a good damper. We used to sell the professional products dampers, but after many failures we discontinued that line. We carry the pro-bond/ pioneer dampers in their place.
Okay, I'm the curious kind. How does a balancer with an sfi rating (I believe that's 13,000 rpm)experience "many failures"? Inquiring minds want to know. BTW, I have been using a PP balancer for about 5 years on several engines with no issue.
[Re: AAR-B4]
#1539767
11/25/13 08:57 PM
11/25/13 08:57 PM
/To get the SFI rating on Professional Products damper they simply rivet a thin ring on the front to keep the outer band from leaving town when it fails--does not keep it from failing. They use a very soft , poor quality rubber. They come apart-- SFI does not mean fail proof or bullet proof just that it lasted a minute on a machine somewhere at ONE time way far away in another galaxy, then...they pay for a roll of SFI stickers that come on a roll like movie tickets and TaDa!
[Re: Michael Ecks]
#1539770
11/26/13 01:05 AM
11/26/13 01:05 AM
Michael Ecks
Columbus, GA
Thanks for the feedback, looks like the Pro Race brand is the way to go for me.
[Re: AAR-B4]
#1539774
11/26/13 09:20 AM
11/26/13 09:20 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I'm using the prostreet damper on my small block stroker. No problems after two years of street use.
I think they're just fine on a street car, and definitely a good alternative to re-using an old stock damper.
If I were racing, or had a four speed, I'd probably go with something better.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: AAR-B4]
#1539775
11/26/13 01:19 PM
11/26/13 01:19 PM
BradH
372 readers, 16 posts and still no specific description of a first hand experience of Performance Products failure.
"RAMM" (Jess Robinson) was running either a Professional Products or 440Source brand (possibly the same part, but he'd need to confirm that) damper on one of his BB EMC entries a few years ago when it failed during the competition. Ask him what happened.
Also, how about a performance machine shop that couldn't get a rotating assembly to balance properly w/ the PP damper installed, so they swapped it out for another brand and resolved the issue? They won't deal with PP dampers anymore.
IMO, for a budget damper, you can only go so "budget" before you're buying a sub-standard part, SFI-certified or not. The Powerbond / Pioneer SFI damper would get my vote under those circumstances.
I know that Jeg's offers that brand under their house label, but you need to look up pictures of the products from both sources to confirm which of the Jeg's-labeled SFI dampers are from Powerbond / Pioneer vs. another supplier.
