Professional Products Dampers. Any good? #1539756
11/25/13 03:56 PM
11/25/13 03:56 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Or who else makes a damper like this.
Similar to stock appearance in front.
LA360 external balance
Counterweights that bolt to rear of damper.
Not chromed.
SFI not needed.
Closest I can find is the Professional Products brand Powerforce Series steel unit, and the ProRace Performance Products brand Pro Street nodular iron.
The Pro-Race is the less expensive of the two, which may or may not be a good thing.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Professional Products Dampers. Any good? [Re: Michael Ecks] #1539757
11/25/13 04:18 PM
11/25/13 04:18 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
We have had better results from the Pro Race brand.
J.C. Childress (434) 665-9541
Re: Professional Products Dampers. Any good? [Re: JC Childress] #1539758
11/25/13 04:35 PM
11/25/13 04:35 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's some options from when I was shopping for a damper.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Professional Products Dampers. Any good? [Re: Michael Ecks] #1539759
11/25/13 04:50 PM
11/25/13 04:50 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i have seen that brand come apart on a 383chevy. came apart and one of the pieces broke the outletfitting clean of the fuelpump also left a pretty substantial dent in the framerail. i wouldnt install that brand on a 318 destined to only run at idle.
Re: Professional Products Dampers. Any good? [Re: 1Fast340] #1539760
11/25/13 05:13 PM
11/25/13 05:13 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a powerforce damper on my 451. Been there for a few years, thousands of street miles, and many trips to 6500. No issues to speak of. I had the motor apart last winter, and the damper looked good as new.
Personally, I believe that most issues people have with many products that arent "top dollar", are actually installation / build errors that get blamed on the part. If its a high dollar part that lets go, its "Wow - Bummer. Good luck figuring out what happened". If its a less than high dollar part, its "thats what you get for buying cheap parts".
Re: Professional Products Dampers. Any good? [Re: StealthWedge67] #1539761
11/25/13 05:32 PM
11/25/13 05:32 PM
The Pro Race and Pro Street are good units
Professional Products not so much--they have soft rubber. I have used a ton of the Pro units on many brands with excellent results.
Pioneer stock replacement is OEM or better quality--very stock looks-- but not cheap
Re: Professional Products Dampers. Any good? [Re: ] #1539762
11/25/13 05:58 PM
11/25/13 05:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Pro Street balancer on 2 different engines including the eng in my 63 right now. I have not had any problems with them and I do race my car sometimes. Ron
Re: Professional Products Dampers. Any good? [Re: 383man] #1539763
11/25/13 06:39 PM
11/25/13 06:39 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I've ran the pro street balancer on 2 engines, up to 7000rpm and lots of street miles...No issues to speak of
Re: Professional Products Dampers. Any good? [Re: 383man] #1539764
11/25/13 07:56 PM
11/25/13 07:56 PM
Delray beach, Florida
P
Performance Only Offline
P
The pioneer brand is made by pro-bond and is a good damper. We used to sell the professional products dampers, but after many failures we discontinued that line. We carry the pro-bond/ pioneer dampers in their place.
machine shop owner and engine builder
Re: Professional Products Dampers. Any good? [Re: Performance Only] #1539765
11/25/13 08:02 PM
11/25/13 08:02 PM
NC
barracuda man Offline
NC
I've been looking at the Jegs dampers.they look real close to that.
Let me tell ya'll about my harmonic balancer experience.keep in mind i have 2 340 motors.I bout one 340 that had the ati damper with the BBC bolt pattern.And a pioneer damper with the 6 bolt SBM pattern on the other motor. I want a msd crank trigger.Part# 8620 kit has the bbc pattern wheel.part# 8633 kit has the sbm wheel.Don't need two different wheel's. What should i do?
Re: Professional Products Dampers. Any good? [Re: Performance Only] #1539766
11/25/13 08:24 PM
11/25/13 08:24 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Okay, I'm the curious kind.
How does a balancer with an sfi rating (I believe that's 13,000 rpm)experience "many failures"?
Inquiring minds want to know.
BTW, I have been using a PP balancer for about 5 years on several engines with no issue.
Re: Professional Products Dampers. Any good? [Re: AAR-B4] #1539767
11/25/13 08:57 PM
11/25/13 08:57 PM
/To get the SFI rating on Professional Products damper they simply rivet a thin ring on the front to keep the outer band from leaving town when it fails--does not keep it from failing. They use a very soft , poor quality rubber. They come apart--
SFI does not mean fail proof or bullet proof just that it lasted a minute on a machine somewhere at ONE time way far away in another galaxy, then...they pay for a roll of SFI stickers that come on a roll like movie tickets and TaDa!
Re: Professional Products Dampers. Any good? [Re: ] #1539768
11/25/13 09:34 PM
11/25/13 09:34 PM
Clinton Township, Michigan
Dartin Online content
Dartin  Online Content
I've learned the hard way.I bought an SFI rated balancer from Summit and had issues with the outer ring slipping. I did not realize it had slipped and reused it on my new build. We found out on dyno after we couldn't get the timing set. I wasted 1/2 a day on the dyno, my builders time, and potentially caused other damage had it not been caught. I guess my point is we all spend good money on machine work, balancing, internals, valvetrain, and even bling. Why not spend the extra $100-150 for a proven part? It cost me more than that in headaches. Call me crazy.....
Randy
Re: Professional Products Dampers. Any good? [Re: Dartin] #1539769
11/25/13 11:34 PM
11/25/13 11:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Randy
Amen brother............
Re: Professional Products Dampers. Any good? [Re: Michael Ecks] #1539770
11/26/13 01:05 AM
11/26/13 01:05 AM
Columbus, GA
Columbus, GA
Thanks for the feedback, looks like the Pro Race brand is the way to go for me.
Re: Professional Products Dampers. Any good? [Re: Michael Ecks] #1539771
11/26/13 06:02 AM
11/26/13 06:02 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
ATI Super Damper, don't go cheap on something this important
Re: Professional Products Dampers. Any good? [Re: 451Cuda] #1539772
11/26/13 07:03 AM
11/26/13 07:03 AM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Professional Products..........just another fine product from our chinese friends.....
Re: Professional Products Dampers. Any good? [Re: SSDart] #1539773
11/26/13 07:52 AM
11/26/13 07:52 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
372 readers, 16 posts and still no specific description of a first hand experience of Performance Products failure.
Here's some first hand experience: I have made spacers for friends small block ATI balancers because they rub the timing cover?
Re: Professional Products Dampers. Any good? [Re: AAR-B4] #1539774
11/26/13 09:20 AM
11/26/13 09:20 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I'm using the prostreet damper on my small block stroker. No problems after two years of street use.
I think they're just fine on a street car, and definitely a good alternative to re-using an old stock damper.
If I were racing, or had a four speed, I'd probably go with something better.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Professional Products Dampers. Any good? [Re: AAR-B4] #1539775
11/26/13 01:19 PM
11/26/13 01:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
"RAMM" (Jess Robinson) was running either a Professional Products or 440Source brand (possibly the same part, but he'd need to confirm that) damper on one of his BB EMC entries a few years ago when it failed during the competition. Ask him what happened.
Also, how about a performance machine shop that couldn't get a rotating assembly to balance properly w/ the PP damper installed, so they swapped it out for another brand and resolved the issue? They won't deal with PP dampers anymore.
IMO, for a budget damper, you can only go so "budget" before you're buying a sub-standard part, SFI-certified or not. The Powerbond / Pioneer SFI damper would get my vote under those circumstances.
I know that Jeg's offers that brand under their house label, but you need to look up pictures of the products from both sources to confirm which of the Jeg's-labeled SFI dampers are from Powerbond / Pioneer vs. another supplier.
