rollbar x braceing #1539244
11/24/13 05:04 PM
11/24/13 05:04 PM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
Anyone run these bars to the upper rear shock mounts?
Re: rollbar x braceing [Re: racerx] #1539245
11/24/13 05:25 PM
11/24/13 05:25 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I did on an earlier cage in my car. Worked great.
Installed one on another early A-body.
Great if you do not have a bender. If you do a halo in the area of the package tray works nicer.
Leon
Re: rollbar x braceing [Re: Leon441] #1539246
11/24/13 08:51 PM
11/24/13 08:51 PM
Mo.
Mo.
Now from my understanding is the x brace helps support the hoop incase of a rollover correct?If thats the case then it just seems stronger to mount it to the frame/upper shock mount than to the floor as i have seen on some cars......JMO
Re: rollbar x braceing [Re: racerx] #1539247
11/24/13 08:59 PM
11/24/13 08:59 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Mine are mounted between the main hoop and frame/shock mounts.
The stiffer the shock mounts are the better the chassis will respond to shock tuning changes.
Re: rollbar x braceing [Re: MPerry] #1539248
11/24/13 09:07 PM
11/24/13 09:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I read the other day that in HP road use, the shocks actually undergo greater loading then the springs, when encountering rapid movements, which is something I hadn't given much concern about, and maybe I should.
Re: rollbar x braceing [Re: jcc] #1539249
11/24/13 09:49 PM
11/24/13 09:49 PM
west palm beach, florida
modelmakerinc Offline
my x braces run to the frame rail between the rear down tube and the ladder bar crossmember, the rear down tubes carry the coil-over shock mounts.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: rollbar x braceing [Re: modelmakerinc] #1539250
11/24/13 09:50 PM
11/24/13 09:50 PM
from trunk
Re: rollbar x braceing [Re: modelmakerinc] #1539251
11/24/13 10:22 PM
11/24/13 10:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Heres mine after I did my back half last winter, put the X bar in from the main hoop down to the frame right where the crossmember is and the down bars end up where the rear crossmember and shockmounts are,,hope they are seeable with my crappy camera at the time.
Re: rollbar x braceing [Re: dartman366] #1539252
11/24/13 10:28 PM
11/24/13 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
looking in to the trunk.
Re: rollbar x braceing [Re: dartman366] #1539253
11/25/13 11:22 AM
11/25/13 11:22 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The most common and effective place to land the X-brace is just above the turn on the attaching area of the 4-link or ladder bar brackets and on the flat of the rail.The down bars to the trunk area can have an upright(vertical) tube from the shock mount cross bar or tube to the down bars for extra support.
Re: rollbar x braceing [Re: B G Racing] #1539254
11/25/13 01:08 PM
11/25/13 01:08 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes the shock mounts are the best place, I try to make every placement tie into as many load bearing points as possible all in triangulation(strongest structure) with as few bars as needed. A bent bar will flex, straight won't.
Re: rollbar x braceing [Re: cudaman1969] #1539255
11/25/13 02:48 PM
11/25/13 02:48 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I personally never liked the "X" in the cage. Looks to NASCARish to me. We did mine a little different but with the same effect. My bars that go down thru the speaker tray go into the upper shock mount bar. Also was able to retain the back seat. Not that anyone will be sitting back there. I just hate the tin look of a race car interior.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: rollbar x braceing [Re: 6PKRTSE] #1539256
11/25/13 02:51 PM
11/25/13 02:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Upper shock bar. And Anti roll bar.
Re: rollbar x braceing [Re: 6PKRTSE] #1539257
11/26/13 01:09 AM
11/26/13 01:09 AM
Mo.
Mo.
Thaxs Gents:
Re: rollbar x braceing [Re: racerx] #1539258
11/26/13 08:55 AM
11/26/13 08:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As mentioned the strongest structure effectiveness is triangulation.With a back halved fullbody car with a high main hoop an x-brace will minimize any lateral flex.With funny car style cages in full tube chassis you have more bars and lower mainhoops and can eliminate the x-brace.With a basic stock floor pan car with stock front suspension you don't necessarly need the X-brace but it does help especially if you eliminate the back seat and trunk floor pans and replace with aluminium..
Re: rollbar x braceing [Re: B G Racing] #1539259
11/26/13 09:51 PM
11/26/13 09:51 PM
Mo.
Mo.
^^^ this is my plan i've already cut out the rear trunk pan and no-longer have a rear seat^^^
Re: rollbar x braceing [Re: racerx] #1539260
11/26/13 10:24 PM
11/26/13 10:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats how I do it... this is my P-body chassis
Re: rollbar x braceing [Re: B G Racing] #1539261
11/26/13 10:33 PM
11/26/13 10:33 PM
VA
VPofGreen Offline
VPofGreen  Offline
VA
BG-
Like this? Look closely in the driver's side rear window..... Is that Santa Claus????
ML
Re: rollbar x braceing [Re: VPofGreen] #1539262
11/26/13 10:39 PM
11/26/13 10:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BG-
Like this? Look closely in the driver's side rear window before you answer..... Is that Santa Claus????
ML
I wouldnt do it like that... should have dropped the X
on the shock cross bar or on the rails at the shock bar...
the X is dropping out in the middle of a length
Re: rollbar x braceing [Re: MR_P_BODY] #1539263
11/26/13 11:18 PM
11/26/13 11:18 PM
VA
VPofGreen Offline
VPofGreen  Offline
VA
The pic may be a little deceiving from that angle. They drop right above the bend where the 4 link is mounted. The down bars also have vertical bars that connect directly to the rails at the shock bar.
