Re: rollbar x braceing
[Re: racerx]
#1539245
11/24/13 05:25 PM
11/24/13 05:25 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I did on an earlier cage in my car. Worked great.
Installed one on another early A-body.
Great if you do not have a bender. If you do a halo in the area of the package tray works nicer.
Leon
[Re: jcc]
#1539249
11/24/13 09:49 PM
11/24/13 09:49 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
my x braces run to the frame rail between the rear down tube and the ladder bar crossmember, the rear down tubes carry the coil-over shock mounts.
[Re: modelmakerinc]
#1539251
11/24/13 10:22 PM
11/24/13 10:22 PM
dartman366
Mt. Vernon, Ohio
Heres mine after I did my back half last winter, put the X bar in from the main hoop down to the frame right where the crossmember is and the down bars end up where the rear crossmember and shockmounts are,,hope they are seeable with my crappy camera at the time.
[Re: cudaman1969]
#1539255
11/25/13 02:48 PM
11/25/13 02:48 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I personally never liked the "X" in the cage. Looks to NASCARish to me. We did mine a little different but with the same effect. My bars that go down thru the speaker tray go into the upper shock mount bar. Also was able to retain the back seat. Not that anyone will be sitting back there. I just hate the tin look of a race car interior.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1539256
11/25/13 02:51 PM
11/25/13 02:51 PM
6PKRTSE
Motor City
Upper shock bar. And Anti roll bar.
[Re: B G Racing]
#1539261
11/26/13 10:33 PM
11/26/13 10:33 PM
Posts: 81 VA
VPofGreen
VA
BG- Like this? Look closely in the driver's side rear window..... Is that Santa Claus???? ML
[Re: VPofGreen]
#1539262
11/26/13 10:39 PM
11/26/13 10:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
BG-
Like this? Look closely in the driver's side rear window before you answer..... Is that Santa Claus????
ML
I wouldnt do it like that... should have dropped the X on the shock cross bar or on the rails at the shock bar... the X is dropping out in the middle of a length
