8 sec tire recomendations?
#1537296
11/20/13 09:45 AM
11/20/13 09:45 AM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I've got some limitations; here they are. 17.7 absolute max section width. They rub a touch with the 2079 GoodYears I have on there now. 33.6 circ, 106 rollout 15.1 wide, 14 inch rim, semi stiff construction. Race weight 3,000 lbs. I run a 4.56 gear, trans brake, 2.45 low Torqueflite, loose converter with about 8 percent slip? Mph is 153 ,looking for maybe 155 possible down the road. Max desired rpm, 7500. What I am looking for is a possibly better tire for overall performance. There is a Hoosier 13.5W x 15 stiff sidewall slick, claims 17.7 section width, but that is about all I see with a decent foot print, narrow enough section width and at least 102 inch rollout. The Hoosier is 5 lbs lighter per tire, and stiff wall construction. Opinions on whether the stiff wall is better are appreciated. Anybody have other tire suggestions, or experience with the Hoosiers? How do the section widths compare? Any extra section width and I would probably be reselling them, so I need input.
Re: 8 sec tire recomendations?
[Re: gregsdart]
#1537297
11/20/13 11:39 AM
11/20/13 11:39 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
hi, you would be supprised how much tire you dont need, had goodyear 1984 32x14 on a 12" rim 2" on outside was not wearing at all so it was like a 10" tire went 8.87 all day 2500 lbs, stiff sidewall was for protree?? better reaction times?? i dont think there is a performance differance??
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#1537298
11/20/13 02:38 PM
11/20/13 02:38 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
I have been very happy with my M/T 33x15's, part number is 30791. My car weighs in at 2940ish and they are work very well. They are a stiff sidewall design. Section width is likely a bit wide for you but possible stepping down to a 14-32 would be better.
[Re: gregsdart]
#1537300
11/20/13 05:00 PM
11/20/13 05:00 PM
Al_Alguire
Las Vegas
Greg yes I run them tubeless. They do leak a little as there is no soap on them, it was making the wheels look funky inside. I have had excellent luck with them.
[Re: Al_Alguire]
#1537301
11/20/13 06:42 PM
11/20/13 06:42 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Love my M/T 16-32-15's on my Daytona but I don't know if you have the room.
[Re: Deepockets]
#1537305
11/21/13 02:12 PM
11/21/13 02:12 PM
Al_Alguire
Las Vegas
I ran Goodyears forever. The issue I had with them is two fold. The major reason was when they went away they went all at once. As in the car worked fine one pass and were goen the next. In this super class stuff we cannot have our 60's vary at all. With the 15x33 GY's I was running they gave no sign of going away they just went.
Secondly and when I made the permamnent switch to M/T was at Phoenix a few years back. It was after that track was having issues with cars wrecking at a division race. I was asking around and watchign what was going on. The cars that were making it down the track in the super classes all had one thing in common for the most part, and M/T tire. So I went over and talked to them and made the switch. The Goodyears I had on the car only had 17 passes on them. I switched to the M/T and viola the issue was fixed and I got down jst fine. I did drop a little in 60', but it was due to the increased rollout of the tire. Ultimately I was able to run quicker ET's as well all out.
[Re: gregsdart]
#1537308
11/21/13 10:01 PM
11/21/13 10:01 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Greg, Jason on Yellowbullet can answer a lot of questions about M/T tires if you need help. GREAT company and tire. http://www.yellowbullet.com/forum/forumdisplay.php?f=107
