8 sec tire recomendations? #1537296
11/20/13 09:45 AM
11/20/13 09:45 AM
gregsdart Offline OP
I've got some limitations; here they are.
17.7 absolute max section width. They rub a touch with the 2079 GoodYears I have on there now. 33.6 circ, 106 rollout 15.1 wide, 14 inch rim, semi stiff construction.
Race weight 3,000 lbs. I run a 4.56 gear, trans brake, 2.45 low Torqueflite, loose converter with about 8 percent slip? Mph is 153 ,looking for maybe 155 possible down the road. Max desired rpm, 7500.
What I am looking for is a possibly better tire for overall performance. There is a Hoosier 13.5W x 15 stiff sidewall slick, claims 17.7 section width, but that is about all I see with a decent foot print, narrow enough section width and at least 102 inch rollout. The Hoosier is 5 lbs lighter per tire, and stiff wall construction. Opinions on whether the stiff wall is better are appreciated.
Anybody have other tire suggestions, or experience with the Hoosiers? How do the section widths compare? Any extra section width and I would probably be reselling them, so I need input.
Re: 8 sec tire recomendations? [Re: gregsdart] #1537297
11/20/13 11:39 AM
11/20/13 11:39 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hi,
you would be supprised how much tire you dont need, had goodyear 1984 32x14 on a 12" rim 2" on outside was not wearing at all so it was like a 10" tire went 8.87 all day 2500 lbs, stiff sidewall was for protree?? better reaction times?? i dont think there is a performance differance??
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 8 sec tire recomendations? [Re: 440lebaron] #1537298
11/20/13 02:38 PM
11/20/13 02:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have been very happy with my M/T 33x15's, part number is 30791. My car weighs in at 2940ish and they are work very well. They are a stiff sidewall design. Section width is likely a bit wide for you but possible stepping down to a 14-32 would be better.
Re: 8 sec tire recomendations? [Re: Al_Alguire] #1537299
11/20/13 04:58 PM
11/20/13 04:58 PM
Al are you running them tubeless?
On the 1984s, I'll check them out too.
Re: 8 sec tire recomendations? [Re: gregsdart] #1537300
11/20/13 05:00 PM
11/20/13 05:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Greg yes I run them tubeless. They do leak a little as there is no soap on them, it was making the wheels look funky inside. I have had excellent luck with them.
Re: 8 sec tire recomendations? [Re: Al_Alguire] #1537301
11/20/13 06:42 PM
11/20/13 06:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Love my M/T 16-32-15's on my Daytona but I don't know if you have the room.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 8 sec tire recomendations? [Re: pittsburghracer] #1537302
11/20/13 09:07 PM
11/20/13 09:07 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
greg, this is like asking on picking a cam for some one. I always ran d2078 goodyears with great results. I decided to try some of the m/t's that were std. side wall. with out any shock adj. I ran one event and sold them. just didn't like the hit off the line and 60's were off. I put a new set goodyears back on, and right back to being spot on. I run 8.40's without muffs and 8.50's on muffs. 159 t 162 mph. 4.56 gear with glide. 7400 thru the traps.
Re: 8 sec tire recomendations? [Re: Deepockets] #1537303
11/21/13 08:41 AM
11/21/13 08:41 AM
Deeppockets, when you say standard sidewall, that may have been the difference? The M/Ts I would try would be the stiff 14x32 tires Al talked about.
Re: 8 sec tire recomendations? [Re: gregsdart] #1537304
11/21/13 09:15 AM
11/21/13 09:15 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
greg, yes the m/t was not a stiff sidewall, and the goodyear is. with the m/t's it did'nt even feel like the front end was lifting, but after looking at some photo's it was. the sidewalls were takeing some of the hit.for me the goodyears hit like a ton of bricks. i'll never try another brand of tire. it's perfect for my set up.
Re: 8 sec tire recomendations? [Re: Deepockets] #1537305
11/21/13 02:12 PM
11/21/13 02:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I ran Goodyears forever. The issue I had with them is two fold. The major reason was when they went away they went all at once. As in the car worked fine one pass and were goen the next. In this super class stuff we cannot have our 60's vary at all. With the 15x33 GY's I was running they gave no sign of going away they just went.
Secondly and when I made the permamnent switch to M/T was at Phoenix a few years back. It was after that track was having issues with cars wrecking at a division race. I was asking around and watchign what was going on. The cars that were making it down the track in the super classes all had one thing in common for the most part, and M/T tire. So I went over and talked to them and made the switch. The Goodyears I had on the car only had 17 passes on them. I switched to the M/T and viola the issue was fixed and I got down jst fine. I did drop a little in 60', but it was due to the increased rollout of the tire. Ultimately I was able to run quicker ET's as well all out.
Re: 8 sec tire recomendations? [Re: Al_Alguire] #1537306
11/21/13 04:26 PM
11/21/13 04:26 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I had the exact same experience with the G/Y as Al. They work great than all of a sudden they would be done. I tried the M/T's for a season. They seemed to work well except at the local track. Track prep varied from really bad to poor. A buddy was using Hoosiers and he was able to hook much better then I could. So I put a set of those on and they seem to work pretty well. Time for another set so I'm debating which flavor this time. BTW, I run a 33x16 with a soft compound.
Re: 8 sec tire recomendations? [Re: Gearhead383] #1537307
11/21/13 09:58 PM
11/21/13 09:58 PM
Thanks guys. Those M/T stiff wall 32x14 look like they are worth trying. I posted on DRR and got similar responses, most in favor of the M/T
Re: 8 sec tire recomendations? [Re: gregsdart] #1537308
11/21/13 10:01 PM
11/21/13 10:01 PM
PA.
"Little"John
"Little"John
PA.
Greg, Jason on Yellowbullet can answer a lot of questions about M/T tires if you need help. GREAT company and tire.
http://www.yellowbullet.com/forum/forumdisplay.php?f=107
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 8 sec tire recomendations? [Re: pittsburghracer] #1537309
11/22/13 12:17 PM
11/22/13 12:17 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We've been 6.17 on our 33/10.5W.
