QA1 Dynamic Strut Rods #1537194
11/20/13 02:20 AM
11/20/13 02:20 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
Hey guys was considering upgrading my stock strut rods on my 70 RR.The dynamic QA1s caught my eye. I am still a bit of a novice so I was curious what advantage they would have over the originals and if you guys think they would be a good addition to a daily driver?
I already have a K member reinforced by Firm Feel and Tubular UCAs and boxed LCA.
Re: QA1 Dynamic Strut Rods [Re: relax383] #1537195
11/20/13 10:09 AM
11/20/13 10:09 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Our strut rods provide the proper interference fit in the LCA mounting hole, and our latest design incorporates a hex into the strut rod for easy adjustments.
Re: QA1 Dynamic Strut Rods [Re: Dan@Hotchkis] #1537196
11/20/13 11:04 AM
11/20/13 11:04 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
is there a new part number?
Re: QA1 Dynamic Strut Rods [Re: relax383] #1537197
11/20/13 11:25 AM
11/20/13 11:25 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
QA1 Precision Products 52312 - QA1 Dynamc Adjustable Strut Barsrs-I run these on my car, very nice and easy to work with.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: QA1 Dynamic Strut Rods [Re: relax383] #1537198
11/20/13 12:36 PM
11/20/13 12:36 PM
No, it was a rolling phase-in. If you order them direct, you'll get the new design.
http://www.hotchkis.net/dodge_be_body_adjustable_strut_rods.html
Re: QA1 Dynamic Strut Rods [Re: Dan@Hotchkis] #1537199
11/20/13 11:22 PM
11/20/13 11:22 PM
IN
ahy Offline
ahy  Offline
IN
I think of the adjustable rods as a problem solver, especially with poly LCA bushings. Factory tolerances were maybe not so tight and who knows what may have happened to the K over the years. If you have geometry/alignment/strut length issues, the adjustables can solve it. I'm using them on an E with poly LCA bushings. With stock rods, there was ~1/8" gap on the thrust surface of the LCA bushing on the left and the alignment would not come in. The adjustables fixed that problem. Alignment is right where I want it now. Just don't crank them too far forward or the bushing will take a beating. If alignment now is OK and no other problems, I believe stock is fine.
I am using FF pieces which are nice. I'm sure others are also.
Re: QA1 Dynamic Strut Rods [Re: ahy] #1537200
11/21/13 07:38 PM
11/21/13 07:38 PM
Renton Washington
Triple Threat Offline
Renton Washington
I run them, they helped the front end of my car @130 mph. Not sure you'll notice much difference on a daily driver.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
