Best paint to replicate bare metal/steel? #1537077
11/19/13 10:13 PM
11/19/13 10:13 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Rustoleum use to make one that was virtually identical but they have changed their formula and the new one appears to be a metalic rather than metal colored.
Careful, your character's showing!
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537078
11/19/13 11:25 PM
11/19/13 11:25 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
if it's not a 3 or 4 season vehicle would RPM be sufficient?
Re: Best paint to replicate bare metal/steel? [Re: can.al] #1537079
11/19/13 11:41 PM
11/19/13 11:41 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I prefer Eastwood's paints. Detail Gray and Spray Gray, quality for sure.......
Admiration For Multiple Carburetor Vehicles...
Re: Best paint to replicate bare metal/steel? [Re: can.al] #1537080
11/19/13 11:53 PM
11/19/13 11:53 PM
mopar346 Offline OP
mopar346  Offline OP
I'm not convinced RPM is right for one that will be driven. I really don't have a reason, I just have concerns. I need to see how it stands up in use for awhile. A properly painted surface will hold up and can be cleaned regularly.
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537081
11/20/13 01:49 AM
11/20/13 01:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Read here if you are considering the painted faux metal look:
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Buy some RPM and try some of the paint methods in the thread above and make a decision that works for you.
Re: Best paint to replicate bare metal/steel? [Re: autoxcuda] #1537082
11/20/13 09:17 AM
11/20/13 09:17 AM
mopar346 Offline OP
mopar346  Offline OP
Thank you.
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537083
11/20/13 10:31 AM
11/20/13 10:31 AM
mopar346 Offline OP
mopar346  Offline OP
Good thread but being 7 years old I will have to see what is still available. Fortunately I did my arms several years ago when I could still get the Rustoleum. I used the Eastwood tint to duplicate the cosmoline, orange and gold if I remember correctly. I also use 6 different colors of cast to duplicate the variance in nature cast parts, that why no 2 parts that bolt together are the exact same shade.
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537084
11/20/13 03:01 PM
11/20/13 03:01 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Seymour's stainless steel paint has a good color plus some rust inhibitors
Re: Best paint to replicate bare metal/steel? [Re: YYZ] #1537085
11/20/13 03:06 PM
11/20/13 03:06 PM
mopar346 Offline OP
mopar346  Offline OP
Thank you, not familiar with that brand, who carries it? Rattle can or sprayable?
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537086
11/20/13 03:15 PM
11/20/13 03:15 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Seymour Stainless Steel is the exact same paint as Eastwood's Detail Gray...except it doesn't have Eastwood's logo and markup on it.
Re: Best paint to replicate bare metal/steel? [Re: burdar] #1537087
11/20/13 05:07 PM
11/20/13 05:07 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Cleaned them very carefully so there is zero rust,then covered ALL in clear coat.Even inside the clamps..Dont mind the bolts..
Testing these to see how good they hold up against rust.. paint vs RPM.
Re: Best paint to replicate bare metal/steel? [Re: 71redcuda] #1537088
11/20/13 05:12 PM
11/20/13 05:12 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
last pic
Re: Best paint to replicate bare metal/steel? [Re: 71redcuda] #1537089
11/20/13 07:46 PM
11/20/13 07:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Been there, done that, even with top dollar clear automotive finishes.....It will rust eventually under the clear...sorry
I've had the best long term results in "clearing" raw steel for cars that will get driven, often, with this....
Re: Best paint to replicate bare metal/steel? [Re: 71redcuda] #1537090
11/20/13 09:14 PM
11/20/13 09:14 PM
mopar346 Offline OP
mopar346  Offline OP
Time out, I was thinking the tie rod sleeves were black, at least on AARs. Am I wrong???
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537091
11/21/13 02:27 AM
11/21/13 02:27 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Most of them were natural steel and some tubes has a darker finish to them. A few were painted from factory i belive.
Re: Best paint to replicate bare metal/steel? [Re: mopar346] #1537092
11/21/13 11:12 AM
11/21/13 11:12 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
anything with threads was unlikely to be dipped or painted
imagine assembling these parts if the threads were full of paint
tie rods sprayed black would not get much paint in the threads
i've seen both..
Re: Best paint to replicate bare metal/steel? [Re: can.al] #1537093
11/21/13 11:29 AM
11/21/13 11:29 AM
mopar346 Offline OP
mopar346  Offline OP
Currently I have my sleeves semi-gloos black (sprayed) and my tie rods raw (cast). To my understanding this is correct, or I guess from what ya'll are saying is an acceptable version.
Re: Best paint to replicate bare metal/steel? [Re: Stewpar] #1537094
11/21/13 11:56 AM
11/21/13 11:56 AM
Nebraska
Dodge-N-Shelby Offline
Nebraska
Looking at Eastwoods website, I see that they have clear powder coatings with different levels of gloss. I wonder if anyone has done their clear over bare metal? Seems like that would hold up better than spray...if you could get the correct look. I have one of the Eastwood powder coat kits but have never used clear, just colors.
Re: Best paint to replicate bare metal/steel? [Re: DAYCLONA] #1537095
11/21/13 02:50 PM
11/21/13 02:50 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Hey Mike,
Do you flatten the gloss on that? The can reads it to be glossy and Im afraid its going to be too shiney.
Im looking to protect the front spring hangers which are raw steel and will be driving the car more than trailering so I want something on them.
Re: Best paint to replicate bare metal/steel? [Re: YYZ] #1537096
11/21/13 06:14 PM
11/21/13 06:14 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
The 'inhibitors' don't last...
If you use it, you'll have to swab with penetrating oil every once in a while...
Been there, done that...
